Phillips 65pfl6502
  • awyatt2
    • Feb 2012
    • 407
    • america
    Phillips 65pfl6502
    Phillips 65pfl6502 I came across this set stuck on ble screen, no menu no sound all inputs dead. I'm thinking main board. The tcon wouldn't stop sound. Right or wrong.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Phillips 65pfl6502
    Most likely main or power supply
    • awyatt2
      • Feb 2012
      • 407
      • america
      3.3 and 10 v on main, don't think power board. Blacklists come on and stay on no flicker or dead spots.
      • dskall
        • Oct 2016
        • 2905
        • usa
        !0v is odd. Without knowing what voltages power board is supposed to put out it is just a guess.
        • awyatt2
          • Feb 2012
          • 407
          • america
          Yeah it's marked 10.2v on the board
          • William1967
            • Nov 2017
            • 217
            • Netherlands
            Download the latest firmware version and upload it. If possible try to find the software with the .pkg extension in stead of the .upg extension.
            Create a FAT32 formatted thumbdrive , place the unzipped file in the root, place the thumbdrive in a USB2.0 port and connect the tv to power. When you use a thumbdrive with a led you are able to see if the firmware is updating, it will also be shown on screen.
              • 12322
              • U.S.
              tv totally dead no indicator light on front, good visual check first, if not see anything obvious, unhook all cables from powerboard, plug powercord into powerboard, check voltages, usually a little legend/map close by that tells expected voltages, at that point probably looking for standby voltage and maybe ac-detect voltage, see what you have.
              • Diah
                • Feb 2013
                • 6613
                are you kidding us ??? TV 65 size work with 10.2 ... how it come and the T-CON need at least 12V. and the sound need at least 24V... post photos to prove you are serious
                • awyatt2
                  • Feb 2012
                  • 407
                  • america
                  No display no picture no menu blue screen only. Found sound by playing with inputs 12 v on tcon fuse good I am gonna try tcon first it's reletavly cheap. I got software I got drive just no way to read what's on screen to update it.good news was I was able to find input to change it to tv channels and find sound. It's either tcon or display from here.
                    • 12322
                    • U.S.
                    ok, I must have glazed over the blue screen, was thinking it said dead with no backlights, yes i think I would try a tcon first, could test it: https://www.youtube.com/watch?v=DiW6nNk1TYA
                    • awyatt2
                      • Feb 2012
                      • 407
                      • america
                      Bad display, tcon, main boards no difference at all. Had to find one with a trashed screen.
                      • Asraf Atb
                        by Asraf Atb
                        01-27-2025, 05:02 PM
                      • paparazzo79
                        sound card dead after graphics card installation
                        by paparazzo79
                        Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                        The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                        I still can not believe that I am such a looser and don't know...
                        07-23-2024, 12:22 PM
                      • ChaosLegionnaire
                        by ChaosLegionnaire
                        09-13-2022, 09:02 AM
                      • flibidy
                        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                        by flibidy
                        I have here a Magnum IA.100 which belongs to my parents.
                        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                        What Ive done........
                        01-01-2025, 01:26 PM
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
