Hi all, I browsed previous threads on Hisense TV's but had some questions I haven't been able to sort out myself. This TV has a red standby light that when powered on, flashes twice, returns to steady, and cycles a few times before returning to a steady solid red.
Poking around the power board (P/N rsag7.820.8349) I have the following voltages with everything disconnected:
Main board connector: 12V ~9.3, STB ~0, VAMP is transient; first measured ~18 and gradually dropping to sub-16V.
Bridge Rectifier: (+) to (-): 167VDC
Filter caps: 368VDC
I've tested every diode, mosfet and cap with a multimeter and didn't come up with any obvious shorts or burnouts. I did notice that 6/8 of the legs of the main transformer are common and test as ground when the circuit is on which seemed odd to me.
I've also noticed there's a faint but consistent "ticking" sound coming from somewhere near the main transformer or varistor portion of the board but haven't been able to pin down what it's coming from. When the board has been disconnected from mains power the ticking sound starts slow and gradually speeds up to steady state (I'd guess 5hz) over ~20 seconds.
I'd appreciate any advice on how to narrow down the likely culprit before I pull the trigger on a full new power board.
Filter caps: 368VDC
