Double Sided Tape
  • Storyteller12
    • Jun 2020
    • 624
    Double Sided Tape
    Just curious what double sided tape everyone uses on the tv screen/ panel when replacing backlights on models like the Samsung ks8000 and mu9000.
    I replaced backlights on a curved model ks8500 and it's started to come apart with the tape I used. Have to redo it now but not sure what's the best tape so I don't have this problem again
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Double Sided Tape
    Double sided thermal tape from Aliexpress. The rolls look blue but the tape inside the blue plastic is white.
    • diif
      • Feb 2014
      • 6978
      • England
      This stuff. https://www.aliexpress.com/item/1005003416030550.html
      • Storyteller12
        • Jun 2020
        • 624
        Thank you, I will give it a try
        • alltvrepairs
          Hisense 55AS6G screen double sided tape required
          by alltvrepairs
          I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
          I need a source for this type of double sided tape adhesive please.
          https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
          Tks!
          07-17-2025, 09:32 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • RetroComputingGrotto
          IBM LTO 7 Tape Drive - Dust Sensors??
          by RetroComputingGrotto
          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
          09-19-2024, 01:54 AM
        • howardc64
          Replaced HiSense 75H6570G backlight
          by howardc64
          TV has 2 strings of LED backlight. 1 string had 1x LED failure. Replaced all LED light bar (thought about replacing just 1 bar but new bar LED color more white compared to old)
          The large screen and HiSense reflector paper assembly presented some challenges over the smaller screens.
          - 75" TV is huge, need 2x large work surface (1 for TV, 1 for LCD panel)
          - White reflector paper in the tub is secured by 10 columns and 1 row (on top the tub) of double sided sticky tape. Took awhile (need to go slow to avoid/minimize damage) to remove with minimal damage.
          05-19-2023, 01:38 AM
        • triplefour
          LG 75UN8570AUD panel issue fixed with tape.
          by triplefour
          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
          07-17-2023, 10:22 PM
