Sony KD-75XE9005 - all lights off
  • amarzahn
    • Feb 2022
    • 7
    It started all with random restarts or the TV being on in the morning and ended with a sudden fail. The stand-by light is dark since then.
    Since then, means the replacement of both power boards
    - APDP-293B1
    - APDP-158A1
    and the motherboard
    BMKS 1-982-022-31
    Still no use. So it is obvious I must have overlooked a single simple fail that probably would not cost as much as I already spent.
    I believe the TV should start even though the back is open?
    I was wondering if the TCON could be dead. But because everything is completely dark the chances are slim.
    Because of the size I am unable to transport the TV somewhere.
    In my city is no service for Sony TVs available.
    So I am pretty much stuck with my dead TV.
    Maybe someone has an idea how to proceed from here.
    Thanks for your support!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KD-75XE9005 - all lights off
    Start with pictures of each board. Check and list voltages going from power to mainboard.
    • amarzahn
      • Feb 2022
      • 7
      That is easier said then done.
      I ordered new boards because I lack the knowledge and time to go through the boards wiring.
      I added the detail pictures.
      220V appears fine. fuses are all good.
      stand-by power output is supposed to be 3,3V.
      I measure 3,5V when the mainboard is not connected.
      After connection, the measured voltage drops to pretty much 0
      I have no idea why that is.
      I added the details in red on the two connected boards.
      Thanks for your support.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Sounds like you have a short in the mainboard.
        • amarzahn
          • Feb 2022
          • 7
          The thing is, I have all boards in duplicate. The mainboard was freshly supplied by Sony itself. I will ask the supplier for advice. But it is hard for me to proof it is faulty.
          • dskall
            • Oct 2016
            • 2905
            • usa
            With the new boards did symptoms change or are they the same? Does standby drop simply from plugging in mainboard? What other voltages are you getting on connector to mainboard? Does power_on voltage change when pressing power button?
              • 12269
              • U.S.
              see if you have any voltage on the BL_ERR pin.
              • amarzahn
                • Feb 2022
                • 7
                OK, i tried to go through the details.
                I disassembled all and but it together on my desk then the mainboard would start (S/PDIF-Toslink lit and powerboard clicks).
                So I figured something is shorting somewhere on the panel.
                I plugged every device together piece by piece.
                Only when I connect the
                Sony Wifi board J20H088
                the mainboard will stop starting and it all goes dark.
                Which is completely weird because I can not see any power modulating features on this Wifi board...
                BUT:
                The TV backpanel is lit, the S/PDIF-Toslink lights up but Google is still not booting up. So besides the Wifi bug there might be something else.
                Maybe with all de-/attaching the cables I ruined some of the flat ribbon connectors for the LCD information of the TCON.
                Any further suggestions?
                Thanks again for your support. It really helped to get this going onward!
                BTW: if I plug in the new mainboard I receive 5 red blinks. I am unsure if that is related to the firmware on the mainboard or if it actually means anything.
                • amarzahn
                  • Feb 2022
                  • 7
                  Update towards the NEW MAINBOARD:
                  flashed current software on mainboard.
                  Now backlight panel is lit but no information on LCD panel shows up.
                  No startscreen. Only after the time booting takes I get this weird Sony Service Sound (chill out music stream), nothing else.
                  The Sony Sound is also shown in a couple videos.
                  If I plug in the WIFI board the whole TV shuts down immediately with the "all black" symptoms from before.
                  I will try to order new flat ribbon cables even though it is weird because if the TCON fails there would be 5 red flashes that I do not have...
                  • amarzahn
                    • Feb 2022
                    • 7
                    OK, the firmware update was tiresome but after a couple reboots it came up just fine.
                    I had to leave the WIFI module unpluged as it was short circuiting something on the mainboard. But I do not use the Smart TV functions anyway.
                    a $10 part causing a couple hundred $$ unneccessary self made repair.
                    I believe a professional service would have not figured this one out either...
                    At least that is what I tell myself ;-D
                    Thanks for your thoughts and support!
                    I will certainly be back with some issues in the future!
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Nice job. Good you kept with it and thanks for the update.
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                      • Audeze
                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                        by Audeze
                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                        Does...
                        10-06-2024, 08:54 PM
                      • Carlos#2003%
                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                        by Carlos#2003%
                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                        02-15-2024, 07:52 PM
                      • Watson306
                        6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                        by Watson306
                        I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                        I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                        I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                        Many Thanks in advance.
                        11-01-2022, 05:33 AM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
