LG Plasma 42PC3D
+ More Options
Posts
  • indypctech
    • May 2010
    • 18
    LG Plasma 42PC3D
    i have a LG Plasma 42PC3D that was working fine till today the screen has gotten dark i have taken a picture
    do you think this has something to do with Z sustain failure
  • NxB
    • Feb 2009
    • 1595
    Re: LG Plasma 42PC3D
    Yes, it is z sustain failure.
    • indypctech
      • May 2010
      • 18
      thank you will order part today
      • retiredcaps
        • Apr 2010
        • 9271
        For us, newbies, how can you tell it is a z sustain failure?
        --- begin sig file ---
        --- end sig file ---
        • PlainBill
          • Feb 2009
          • 7034
          The symptoms. The very dim picture (sometimes a picture is only visible in the lower right corner) is very characteristic of LG Electronics TVs using the 6871QZH056A (or B, or C) Z-sus. Either replace the board, or replace the hybrid.
          PlainBill
          • Keshenatech1
            LG 50PJ350 plasma blowing Y-Sustain board
            by Keshenatech1
            Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
            05-13-2020, 10:08 AM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • pixelcap
            Pioneer Plasma 111FD To Solder or Not to Solder.
            by pixelcap
            Hello out there in Badcap land.
            I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
            are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
            Thank you
            Pixelcap...
            03-08-2025, 07:10 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • ctroxtell
            Carrier HK50AA063 display controller common failure help
            by ctroxtell
            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
            02-05-2025, 05:31 PM
