Vizio E550i-b2e no standby voltage
  • Mbd3
    • Feb 2022
    • 25
    Hi All, I have a vizio e550i-b2e that has no standby voltage. I am hoping some one can help. I am getting 10-14volts bouncing at pin 5 of ic901 (Vcc). According to the data sheet for that ic I need atleast 16v for it to turn on. I did a thermal scan and the only thing that glowed was d901.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E550i-b2e no standby voltage
    You need to check all diodes, caps, resistors, mosfets around IC901for shorts and opens.
    • Mbd3
      • Feb 2022
      • 25
      I have. Everything checked as it should. I was wondering if maybe that d901 is stealing current from ic901? Maybe the diode is a little leaky? Sorry I am a complete newbie.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Can you post datasheet?
        • R_J
          • 9588
          Replace C907 and C904B, Do you have any voltage at D950B cathode?
          • Mbd3
            • Feb 2022
            • 25
            I did replace the capacitors and I am trying to find the d950.
              • 12276
              • U.S.
              D950b is right by connector cn101, looks like they did not use D950a.
              • dskall
                • Oct 2016
                • 2905
                • usa
                No short between pin 1 and 7/8 of IC?
                • Mbd3
                  • Feb 2022
                  • 25
                  Ok thank you. I have 0volts on D950B.
                  • Mbd3
                    • Feb 2022
                    • 25
                    No everything looks good. From my understanding the ic takes current for the drain pins 7 and 8 and applies it to start the pwm then charges the cap for vcc. Then the aux winding is suppose to take over. However like I said the Vcc doesn't go over 14.5v and it needs 16 to turn on.
                    • R_J
                      • 9588
                      The vcc voltage you are seeing on pin5 is likely from the internal startup cell, Check the source resistors, R907a,b if they are ok, I suspect the ic itself could be bad, if it was trying to start you should see a volt or two on D950b as that is the output of the standby voltage, just be sure there is no short on the standby output killing the voltage
                      • Mbd3
                        • Feb 2022
                        • 25
                        I have put 3 ics in so far same results. I had the 5v stand by and then gone and can't get back.
                        • Mbd3
                          • Feb 2022
                          • 25
                          You can see everything looks normal except for D901
                          • Mbd3
                            • Feb 2022
                            • 25
                            I know I can buy a new board, but now this is a pride factor I will not let a board beat me lol
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              So did you have shorted pins on the ic's you replaced?
                              • Mbd3
                                • Feb 2022
                                • 25
                                No everything checked good.
                                • R_J
                                  • 9588
                                  What other parts have you replaced and did not mention? What did you do that caused the 5v standby to die? did you short something?
                                  Check that you don't have an open transformer winding between pins 1&4 and also the output pins 5&7
                                  • Mbd3
                                    • Feb 2022
                                    • 25
                                    I replaced all together IC901, C907, C904B, C903, C901, Q800, andR804A
                                    • R_J
                                      • 9588
                                      What was wrong with Q800 & R804A? they are for the pfc circuit not the standby circuit. however if Q800 was shorted it may have damaged ic801 and ic801's vcc voltage is supplied by the standby circuit D902 via the transistor connected to J14
                                      Also if ic901's internal mosfet shorted, it may have damaged the source resistors or shorted zd909, zd909 would need to be removed to check it because it is across the low value source resistors R907.
                                        • 12276
                                        • U.S.
                                        maybe look all the solder joints over closely, might be just the picture but the joints on BD1 and D120 look a little suspect.
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • x_orange90_x
                                          Samsung UN55KU6300F no standby voltage
                                          by x_orange90_x
                                          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                          05-21-2025, 09:59 PM
                                        • Bad_IC
                                          Philips TV 37pfl5604h/12 no standby voltage
                                          by Bad_IC
                                          I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                                          These are the voltages in some pins of IC fsq510:
                                          Vcc=18v
                                          D=320v
                                          Vstr=154v
                                          Unfortunately, I couldn't find the schematic
                                          What else could I check?
                                          Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                                          Thank you​...
                                          11-08-2024, 01:07 PM
                                        • brock-s
                                          Asus GL503GE 3.3 standby voltage low
                                          by brock-s
                                          An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                                          Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                                          Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                                          07-13-2023, 03:43 PM
