LC-46D62U capacitor decoding help
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Have been unable to find a coding chart for this cap. as to uf's and voltage. Any help appreciated.
    • 12276
    • U.S.
    Re: LC-46D62U capacitor decoding help
    looks to be 625uf 100v. edited to say DISREGARD I was wrong.
    • diif
      • Feb 2014
      • 6978
      • England
      It's 100uf 6.3v.
        • 12276
        • U.S.
        Right, my bad, the top number is the lot number.
          • 12276
          • U.S.
          they can be tricky to decipher, was just about to correct myself after watching this video with a good description: https://www.youtube.com/watch?v=DEfqXCBKwV4
          • whiz62
            whiz62
            • Dec 2013
            • 242
            • usa
            Thanks guys! Got this TV given to me and tracked it down to bad main board. All it would do is just click on start up and replaced the main three times from various vendors. All those mains would work but had the issue of grid like lines over screen and could change screen by flexing the main. Just thought I would try and see what I can do with the original board since I don't want too much invested in something this old.
              • 12276
              • U.S.
              I completely understand, trying to fix my mainboard too, because they want way too much for a used board, the only good info. I'm getting is the youtube videos but they're mostly in hindi, one guy is fixing mainboards by the handful but I can't understand a word he's saying.
              • whiz62
                whiz62
                • Dec 2013
                • 242
                • usa
                nomoresonys, I know what you mean. I try hard to understand but fially just give it up. Would like to get it going. The TV is built like a Tank!
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                • chth96
                  How can I test non-polarized capacitor?
                  by chth96
                  I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                  I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                  And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                  I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                  06-02-2024, 07:31 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
