Samsung UE65h5400AW Won't Turn On (Has Red Standby Light)
    • 12274
    • U.S.
    #41
    Re: Samsung UE65h5400AW Won't Turn On (Has Red Standby Light)
    I have only had to do this once, so I'm not an expert, what I did was go to the update page of support and it tells what model tvs that the firmware will work with, then I bought a mainboard from one of the models on the list, my suggestion is to look at that list. I can not guarantee of course. I would check and see if this one is on the list, my guess is that it is: https://www.ebay.co.uk/itm/363726013....c101113.m2108
    • DutchDIY
      • Feb 2022
      • 51
      • Nederland
      #42
      Originally posted by Diah
      i wrote on your early post.. yours MB working... now its shorted and it could be because you went to messure voltage on chips op on useres request. which was all fine.. so the short happen.
      What can I do about it?
      • DutchDIY
        • Feb 2022
        • 51
        • Nederland
        #43
        Thanks, will take a look.
          • 12274
          • U.S.
          #44
          did some quick checking and this one seems like the proper download page: https://www.samsung.com/ie/search/?s...6400AW#support
            • 12274
            • U.S.
            #45
            here's a hot tip, download and save the firmware, EVEN if you don't need it right now, these guys are notorious for taking firmware off their site, never to be found there again.
            • DutchDIY
              • Feb 2022
              • 51
              • Nederland
              #46
              Downloaded the files, good tip!
              Unfortunately I don't see a mention of other models for this firmware file.
              • DutchDIY
                • Feb 2022
                • 51
                • Nederland
                #47
                Should a new main board fix my tv?
                  • 12274
                  • U.S.
                  #48
                  Pretty good chance it would, in my opinion.
                  • DutchDIY
                    • Feb 2022
                    • 51
                    • Nederland
                    #49
                    This tv has been revived, thanks guys!
                    Put in a new motherboard (literally new.. came from new broken screen tv), for €80,-.
                    So this tv is good to go for years to come!
                    (The board on the photo is the old one that came out)
                      • 12274
                      • U.S.
                      #50
                      Glad to hear it, another fine save.
                      • DinBak
                        • Dec 2021
                        • Netherlands
                        #51
                        Originally posted by lotas
                        Check the voltages on the converters on the motherboard.
                        I have a same faulty board with an overheated IC206. Do you know the type of this IC ?
                        Maybe you even have an electric schematic?
                        • lotas
                          • Jan 2016
                          • 4747
                          • Russia
                          #52
                          Originally posted by dinbak
                          i have a same faulty board with an overheated ic206. Do you know the type of this ic ?
                          ic206 (z3015pi) - aoz3015pi
                          • DinBak
                            • Dec 2021
                            • Netherlands
                            #53
                            Thank you very much, it wil help a lot.
                            Maybe you even have an electric schematic of the board too ?
                            • lotas
                              • Jan 2016
                              • 4747
                              • Russia
                              #54
                              I don’t have a diagram, I have a service manual, but it doesn’t have a diagram.
                              • ChristianBr01
                                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                by ChristianBr01
                                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                04-23-2025, 01:48 AM
                              • Kaar3l
                                Samsung QLED QE65Q7FNAT only standby light
                                by Kaar3l
                                TV: Samsung QLED QE65Q7FNAT
                                PSU: BN4400940A
                                MB: BN94-12832K
                                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                09-24-2024, 01:35 PM
                              • PNI E.
                                Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                by PNI E.
                                Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                03-17-2025, 04:23 AM
                              • Nicktronic
                                Samsung UN70NU6070F Standby Light flashes twice
                                by Nicktronic
                                Hey Everyone,
                                So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                03-27-2023, 07:01 PM
                              • Jackching
                                Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                by Jackching
                                I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                04-15-2024, 05:14 PM
