Philips Pus 436401/12 flashing backlights question
  • KevM
    • Feb 2021
    • 17
    • united kingdom
    Re: Philips Pus 436401/12 flashing backlights question
    Yes i did remove one of the small SMD resistor on both ICs to slightly limit the current flow ,my thinking was the new leds may be rated different but did not make any difference so i haven't replaced it as yet .I am thinking along the lines as you, open circuit on the LED- which gives me the voltage fluctuation mentioned in post 1 the heat sinks do seem to get quite hot and i cannot find a data sheet for the TPV101AD chip. Ill test the diode mentioned and try to see if i can make sense of the IC readings.
    • Diah
      • Feb 2013
      • 6503
      this is service manual for yours BL circuit which it used by sharp too.. you can check TPV101AD
      • KevM
        • Feb 2021
        • 17
        • united kingdom
        great thanks for that
        • KevM
          • Feb 2021
          • 17
          • united kingdom
          Just a quick update i flipped the board over with the intention of testing volts on the Ics and decided to try the freeze test and see if any component warmed quicker than the other . After switch on i normally get 15 seconds before the LEDs flash on and off but it was around 2 minutes before the on/off sequence started and only the 2 tpv101s got warmer quicker than anything else. Vcc was 12v and dim was 3.3v constant. Ill do more testing tonight when i get home.
            • 12314
            • U.S.
            Wonder if caps c8624 and or c8627 might be a little weak, maybe double check that all the backlight connections are solid, did you use a backlight tester or test each led?
            • KevM
              • Feb 2021
              • 17
              • united kingdom
              #26
              thanks all leds are brand new and they test good with an led tester. Check continuity on the wiring and checked ok i will check the caps you mentioned and possibly swap them out as i have a scrap G7350 board with very similar set up which strangely enough does not have the 2 low ohm resistors just a jumper in place.
              • Diah
                • Feb 2013
                • 6503
                TPV101AD the way they are warm and the effect of heating left on print boards.. time to replace them both with out thinking twice.
                • KevM
                  • Feb 2021
                  • 17
                  • united kingdom
                  #28
                  hi Been away for a couple of days so only just read the post .
                  Unfortunately tpv101D is only available from china and have had bad experience of fake items from china. Is there a better alternative to that chip with same/ better specifications available from UK supplier.
                  • Diah
                    • Feb 2013
                    • 6503
                    they are made in china.. UK / EU/ USA didn't make them.. and they are not a complex IC. so don't hesitated to place order from uncle XIN
                    • KevM
                      • Feb 2021
                      • 17
                      • united kingdom
                      #30
                      quite agree that just about everything {tv wise} on the forum originates from china i will order and get back to you when they arrive and fitted .
                      • betmen
                        • May 2019
                        • 90
                        • Croatia
                        #31
                        Did you changed TPV101D chips and did you repair backlight?
                        I have similar problem with my tv...
                          • 12314
                          • U.S.
                          #32
                          5 months? must be the slowest boat from china ever, or maybe he's just too busy to bother reporting back.
                            • 12314
                            • U.S.
                            #33
                            So we're left to speculate that, the 2 ics fixed it or he fixed it another way or he gave up???
                            • KevM
                              • Feb 2021
                              • 17
                              • united kingdom
                              #34
                              In answer to the last post on here yes i did give up or rather put it to bed for a while. But i will now tell what the outcome was or what i discovered was that my tv which was an auction site cheap buy and had been repaired before and fitted with a replacement power board which was not the correct one for my tv.
                              It should have been a philips 715G-7350 but was instead a 715G-6973 which is known to have the problem when backlights are changed.
                              The tv worked fine for around a year or more till the problem occured and only when an exact same model came up on an well known auction site and i won it with the intention of salvaging 2 tvs into one that i discovered the dicrepancy.
                              So i now have a functioning tv simply by having the correct power board in.
                              so anyone with the same problem check which power board you have and best of luck trying to find a 715G 7350 as they seem to be like gold dust.
                              post concluded unlike a lot of others on here. many thanks for peoples input.
                                • 12314
                                • U.S.
                                #35
                                You solved it, good to hear. Lots of people work hard here trying to help people, so hopefully it isn't asking TOO much, to get an update, doesn't really matter to me but I do consider it very bad manners to just quit responding in the middle. I always just assume they wandered into the Bermuda Triangle or Quicksand or got hit by a bus etc, etc...
                                • STKR123
                                  Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                  by STKR123
                                  As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                  I wonder if re-flashing the BIOS might be of any use here.
                                  As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                  There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                  11-03-2024, 06:58 AM
                                • rddube
                                  LG 50lb6100 flashing backlights unsusual fix!
                                  by rddube
                                  Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
                                  Read all the discussions on the web and on Badcaps (wonderful forum!!) and...
                                  03-16-2022, 05:46 AM
                                • djmka
                                  Philips 65PUS6554/12 - only powers on if you prime backlights first
                                  by djmka
                                  Hi everyone.
                                  I have a problem that I would appreciate some expert advice on.
                                  I have a 65” Philips television which powers on, has sound but but no picture. Usually this would lead me to believe an open circuit was present on the backlights. However, if I disconnect the mains power cable to the television and test the power cable going to the backlights using a LED tester, no open circuits are present. If I reconnect the backlight cable to the power board and replace the mains power cord to the tv the device fires up perfectly and displays a beautiful picture. It's almost as though...
                                  08-31-2022, 03:12 AM
                                • Bloopeta
                                  Panasonic TX-55CX400B backlights flashing on and off
                                  by Bloopeta
                                  Hi peeps, have a Panasonic TX-55CX400B here, guy I got it from said he tried to turn it on other day, and no backlights.
                                  When I received it last night, I plugged it in, and it came straight on and appeared to be working fine, so knowing this would only be temporary, I left it running for a good few hours, and they eventually went off. I tried turning it off and back on again, and this time the backlights started flashing at a steady continuous pace. So I turned it off and left it overnight as it was getting late.
                                  This morning when I turned it on, same problem, backlights...
                                  12-04-2019, 01:45 AM
                                • whtiey549@gmail.com
                                  PHILIPS 42PFL4606H/58 NO backlights
                                  by whtiey549@gmail.com
                                  Hi all, I have a philips 42pfl4606h/58 and there are no backlights. I can hook up my laptop and play video through the set. Sound but no picture. I can use a flashlight and see picture through the screen.
                                  I will attach some photos. Are the CCFLs good? How can I test the board? Without Electrocuting myself. Any help would be greatly appreciated....
                                  06-13-2022, 07:47 AM
