LG 70UH6350 Mainboard issue
  • Diah
    • Feb 2013
    • 6355
    Re: LG 70UH6350 Mainboard issue
    sorry i did mistake.. Tuner related to 12V rail
    only DCDC 5V normal /USB & Audio Amp
    • Storyteller12
      • Jun 2020
      • 624
      Did some more testing and found this coil L2307 shorted to ground. I'm removing now to see if it clears the shorts on the smd caps.
      • Storyteller12
        • Jun 2020
        • 624
        Thanks Diah, I found both shorted. However it’s not shorted to ground.
        I’m removing them now to test
        • Storyteller12
          • Jun 2020
          • 624
          Sorry, I was thinking they were caps. that why I thought they were shorted. They just have continuity.
          • Diah
            • Feb 2013
            • 6355
            if you mean on the one you marked ,, C730 its labeled DUMMY will read short LOL
            look on the L i remarked to you before.. open them one by one the 24 will back to normal i suspect DCDC so start with it.
            • Diah
              • Feb 2013
              • 6355
              they are the internace of 24V to DCDC and Audio AMP. one by one need to take out and turn on check your 24V back to normal.
              • Storyteller12
                • Jun 2020
                • 624
                Ok. I took each one out and still tested 27v. However I did replace the one I took out first l5800 before taking the second one out of circuit l2038. After I remove l2038 I did get red light on optical audio port
                • Storyteller12
                  • Jun 2020
                  • 624
                  Also still have shorted smd caps with l2038 out
                  • Diah
                    • Feb 2013
                    • 6355
                    you said the Optical work now... are you sure the 24V still high?
                    • Diah
                      • Feb 2013
                      • 6355
                      keep L2308 out from boards... you need to test this 2 zener zd2303 zd2300
                      dont give any attention on c703 its dummy. mean both pins connected together
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Quick update. The L2038 is measuring 11.77v so that’s not tied to the 24v.
                        I did test the zener diodes
                        Zd2300 measure 592 one way and 409 the other way.
                        Zd2303 shorted together one way reading 043 and 081 the other way but not shorted
                        • Storyteller12
                          • Jun 2020
                          • 624
                          Also I made a mistake by plugging in the tcon each time I powered on. After unplugging that completely I got the 24v down to 25.3v.
                          So I’m guessing the tcon is bad also but is the 25.3v is still high correct.
                          • Storyteller12
                            • Jun 2020
                            • 624
                            Another note the optical audio doesn’t always light up. If I completely unplug it from the power supply it will light up. But if I just power down from the remote and power back on it doesn’t light up.
                            • Diah
                              • Feb 2013
                              • 6355
                              because we dont have the service manual... if L2308 12V rail then look on other circuit IC and its L most time will have same NO, from yours OP photo i cant see it very well--
                              if you removed the T-CON .. T-CON took Panel VCC from 12V, rail,
                              • Storyteller12
                                • Jun 2020
                                • 624
                                All the ic circuits with L that measured 25v I removed but unfortunately none seems to solve the problem and bring voltage back to 24v. Might have to throw the towel in on this one for now and hope to find a used board in the future
                                • R_J
                                  • Jun 2012
                                  • 9535
                                  Having 25v on the 24v supply is not your problem, that 24 volt supply is not regulated that close and if the tv is not operating there will be very little load on that supply so the capacitors will charge to a slightly higher voltage.
                                  When you tried the other main board and had backlights, did you also get an image on the screen? ie menu
                                  • Storyteller12
                                    • Jun 2020
                                    • 624
                                    I can’t test the image because it’s a slightly different main board and doesn’t match the tcon. The power supplies are the exact same so I knew it would work to test the backlights.
                                    • nomoresonys
                                      • 12098
                                      • U.S.
                                      #58
                                      Quick update. The L2038 is measuring 11.77v so that's not tied to the 24v.
                                      These readings don't seem right, I would take them out of circuit and test them again, unless there's a reason for those readings.
                                      • Storyteller12
                                        • Jun 2020
                                        • 624
                                        My 12v tested fine and that circuit is tied to the 12v rail so Im just assuming that those diodes are fine. I would like to find what is shorting all the smd caps and the 1 ic I mentioned a few post back. Since I don't get backlights I'm guessing it's something on that part of the circuit.
                                        • nomoresonys
                                          • 12098
                                          • U.S.
                                          #60
                                          https://www.youtube.com/watch?v=XhqwC3BFBug
                                          • max789
                                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                            by max789
                                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                            I made the following tests:
                                            1. Disconnected the main board from Power Board = backlight works.
                                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                                            So I ordered a main board from Ebay also BN41-02156A but from...
                                            01-18-2024, 06:56 AM
                                          • alltvrepairs
                                            Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                                            by alltvrepairs
                                            I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                                            This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                                            Any help appreciated!...
                                            03-14-2024, 03:39 AM
                                          • dbuergi
                                            PS5 Dualsense controller stick drift a mainboard issue?
                                            by dbuergi
                                            I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
                                            I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
                                            05-02-2025, 05:00 PM
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                            🛠 Original Issue
                                            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
