sharp LC70EQ10U 2 slow, 2 fast blinks
    • 12276
    • U.S.
    Re: sharp LC70EQ10U 2 slow, 2 fast blinks
    Glad to hear it, that's a nice size screen, to me a 70 inch tv is just like being at the theater BUT better you can control the volume, at the theater the sound just about makes my ears bleed, too loud.
    • Diah
      • Feb 2013
      • 6440
      LOL 70 from years 2013 less or more he should direct with out thinking twise to bring the LED backlight at least to 35%
        • 12276
        • U.S.
        I like the old stuff, it breaks a lot less, have a sharp tv got it new in 2007, runs at least 12 hours a day, last new one I bought by the way, never had a bit of trouble with it.
        • JayPoorJay
          • Jan 2022
          • 149
          I like older stuff as well. More, I hate to see perfectly good things end up in the dump. Even more than that, for the amazons of world - the idea that we repair things has all bit been a shattered idea.
          I am super happy that for just a little $$$ and a little tinkering I was able to salvage and ENJOY something that was going to be taking up space in a landfill and adding to polluting our lil world...
            • 12276
            • U.S.
            Hell ya, if we don't fix it then china just gets richer faster, not that all things are made in china but a LOT are.
            • JayPoorJay
              • Jan 2022
              • 149
              Shoot!
              So, got a stand, been turning the thing on for days since "fixing" it and today, went to turn it on in anticipation of putting it on the stand and setting it up and BAM. Something that's happening that wasn't, when I turn the TV on SHARP comes up on the screen in bright red,,, that disappears and the TV seems to go to the next step - I see a input kind of menu item - telling me the INPUT and a channel I think. Then I hear the faintest click or a soft tap and the screen shuts off. It's strange. Then,,, slow single blink, then a fast single blink Wich, from the chart about be, indicates lights...
              I was getting that blink pattern before and when I did a hard rest it came together. Blinking stopped and tv worked
              Now, when I try to get to that K mode to get to those settings again, K comes up briefly to give me the menu with a static-y screen,,, then shuts itself off.
              I'm all kinds of confused.
              • diif
                • Feb 2014
                • 6978
                • England
                #27
                If you had a lamp error because they are faulty and just cleared the error the faulty lamp is still there.
                • JayPoorJay
                  • Jan 2022
                  • 149
                  Understood... Thing is, my initial error was a powerboard error... Is it possible that the reset kinda solved that briefly and now it's resurfaced? The TV has been working for days.
                  It's strange. In these short few days since "fixed" I don't remember it coming on/up with the sharp logo immediately. Then, also, it says the TV is in analog mode.
                  Earlier today, turning it on for the first time of the day, the Roku screen came up immediately and all seemed fine.
                  What do I need to do next?
                  • JayPoorJay
                    • Jan 2022
                    • 149
                    Yeah... This thing is nutty. I put on my cave head light,,, force started it using channel up volume down buttons and the screen was black. Could see images with light and was able to get into the MENU. I had to RE-program the remote (don't know why) and then did a hard reset. TV came on immediately. All areas of the screen look normal as in no areas are darker than others but I guess that doesn't tell the whole story... Lol,,, what have I got myself inta!?
                      • 12276
                      • U.S.
                      #30
                      Might be a dirty connection, maybe clean all connections and ribbon contacts gently with isopropyl alcohol and a qtip, some use a pencil eraser, maybe plug and unplug connectors a couple times.
                        • 12276
                        • U.S.
                        #31
                        I suspect there's a problem with the mainboard, all the voltages are as expected on powerboard right?
                          • 12276
                          • U.S.
                          #32
                          Could try a firmware update if available, if you haven't already.
                          • JayPoorJay
                            • Jan 2022
                            • 149
                            So, left the thing in all/over night. Things seem fine.
                            Turned it off then back on, all good.
                            If it's what you mean I "updated" the TV using the menu options that described an UPDATE immediately after the first hard reset. It took the update and it took a while. Is that a firmware update or is there something more?
                            I have no problem removing the back again and removing and replacing plugs. I pulled and reset all the pin connector style plugs at all clear and visible small wire looms,,, but NONE of the ribbon style connectors, but can and will if the problem persists. I have a product called DeOxit, small spray can, and alcohol. Lots of qtips for this sort of thing.
                            For checking voltages with a DVM/DMM I will need your help with that, lots of it, BUT, I think I am capable.
                            Seems like if the lights are shot I'm out of luck. I've read that there are NO replacements...is that true?
                              • 12276
                              • U.S.
                              #34
                              Yes that's it, so you are updated, that's good, not sure if those lights are still available, do the simple reset, with tv unplugged hold power button on tv in for 30 seconds to a minute let go, plug tv in and try it, but maybe only if it acts up again.
                                • 12276
                                • U.S.
                                #35
                                It's led backlit, so even if they don't sell the whole strips, you can always change out the individual bad leds, not real easy but not real hard either, there's a crapload of how to change m out videos on youtube.
                                • JayPoorJay
                                  • Jan 2022
                                  • 149
                                  Got you... I'll keep my eye on it and see what happens next.
                                  Brother, thank you for your help and reassurance. Really!
                                  All of y'all.
                                  One more thing for now. I hear that getting into the area of these TV's is very fragile work. Where getting to the area of the TV where the lights live, one can basically destroy the screen, or something. Is it really THAT fragile a procedure - or is that kinda overstated? Just wondering.
                                    • 12276
                                    • U.S.
                                    #37
                                    Yes indeed, even the pros break them, the bigger the screen the easier they are to break, check youtube on procedure, with a 70 you should probably have help and maybe 4 of the suction cups that are used for this kind of repair.
                                      • 12276
                                      • U.S.
                                      #38
                                      Ok, so this tv is edge lit, so it might be harder to replace individual leds on the backlights, not sure haven't had one of these on the bench.
                                      • JayPoorJay
                                        • Jan 2022
                                        • 149
                                        Ok. Again, thanks.
                                        Just watched this video https://youtu.be/YgaL6X6eSaU . I will find more to take a gander at. (the BC site isn't allowing me to create links...?)
                                        I'm sure the procedure isn't exactly like the vid as it's a different TV but ok.... Also,,, who the heck knows if there are even replacement lights...? Anywho.
                                        Not bragging, but the procedure doesn't look to scary or beyond my ability. I would get the supplies you suggest should it come to that and I still feel like I would be way ahead of the game if I spent 1 or 2 hundred bucks.
                                        Still,,, the back lighting seems fine when the TV is on,,, so maybe the fault lies somewhere else. We'll see. For now I'll just wait and see what happens next - mentally reassured that if it starts playing up again I'll have a few more tricks up my sleeve...
                                        Many thanks, have a great day.
                                        All kinds of snow here today πŸ˜–
                                        • Diah
                                          • Feb 2013
                                          • 6440
                                          Originally posted by JayPoorJay
                                          reduce the BL level at setting so you will have double life time of their rest time
                                          • joblo37pam
                                            Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                            by joblo37pam
                                            It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                            The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                            10-26-2023, 02:17 PM
                                          • Caimano
                                            hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                                            by Caimano
                                            MB G7AD-2G DAG7ADMB8D0 REV D
                                            Processor i5 8265U
                                            AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                                            Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                                            Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                                            02-06-2024, 10:14 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Anzio
                                            Sharp LC60E79u 2 blinks power/3 Blinks OPC
                                            by Anzio
                                            I have a Sharp LC-60E79U with the blinking light error (Power and OPC blink 2 times together then OPC blinks 1 time. I read the previous thread on Sharp lc60e79u (https://www.badcaps.net/forum/showth...t=66913&page=3) with this same issue, but no resolution was posted.
                                            The service manual indicates this as a β€œDET_5V (33pin) error (L). 5V is not applied.”
                                            I cannot enter service mode by pressing input and channel down and plugging the unit in to power outlet. However, I can override and enter the diagnostic mode if press channel down and volume up and...
                                            07-03-2020, 01:12 PM
