Samsung UN55EH6000F Power issue
  • R_J
    • Jun 2012
    • 9581
    Re: Samsung UN55EH6000F Power issue
    But what else did they damage when they went bad? usually components in the gate circuit get damaged as well, Also have a look at CL802 (blue cap) does it look bulged at all?
    • CraigR
      • Dec 2013
      • 965
      Pulled all caps and tested with ESR meter and were almost spot on. No bulging either. I had to also replace RL820 was open and also replaced the zener diode ZDL802 was also open.
      • R_J
        • Jun 2012
        • 9581
        Originally posted by R_J
        The resistor is ok. That is the source resistor for the pfc mosfet.
        If ZD802 went open, I suspect RL822 could be open as well, and if both mosfets were shorted, I would change ZDL801 as well.
        If any components in the gate drive are not correct, the circuit will not switch properly and draw too much current.
        • CraigR
          • Dec 2013
          • 965
          RL822 checks ok and I did replace ZDL801 at the same time as other one. Thank you R_J for your time as it's much appreciated. I need to quit for the day but if you think of something please let me know and I will check it in the morning and report back ASAP.
          • CraigR
            • Dec 2013
            • 965
            R_J I was thinking that when I checked voltage at the big cap it was also fluctuating so would still be a problem on the hot side of the board. Would the rectifier have anything to do with it???
            • R_J
              • Jun 2012
              • 9581
              explain Fluctuating, Fluctuating from 385v to ???
              What rectifier? there are lots of them on the board, and they all have board identifiers
              If QL801 & QL802 are not switching properly, they will likely cause the main pfc boosted voltage to drop. but it should not drop all the way down from 385 to 160v
              • CraigR
                • Dec 2013
                • 965
                Well it happened so fast and was never a steady voltage on the big cap. I think I seen 380v then down to 100 something but was very fast. I was asking about BD801S I think it is. Would you think I just try replacing QL801 and QL802 again? In case I got some bad new ones??
                • R_J
                  • Jun 2012
                  • 9581
                  The main supply should not drop below 165vdc, I can see the pfc circuit shutting down and the voltage dropping from 385v to 165v
                  The mosfets may have been damaged if they were replaced before the gate resistor and zener were replaced.
                  BD801s is the main bridge rectifier, I doubt it is bad, none of the 4 diodes are shorted or it would blow the main fuse and it is unusual for one of the diodes to o open.
                  The whole board seems to be working except for the backlight supply circuit, and when the backlight circuit is working it should supply 331V at 289ma which is not that much of a draw on the main supply, and with no led's connected (unloaded)it should not be drawing much current at all.
                  • CraigR
                    • Dec 2013
                    • 965
                    Replaced them both again and still no joy. Here is a pic of old one on left and new on right.
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • Cookybaby
                      Samsung UN60ES6500FXZA Power Supply Issue
                      by Cookybaby
                      Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                      I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                      Make: Samsung
                      Model: UN60ES6500FXZA
                      Power Supply P/N: BN44-00525A
                      Symptoms: The TV was...
                      08-20-2023, 12:26 PM
                    • Drewwol11
                      Samsung QN49Q70RAFXZA Power Cycling Issue
                      by Drewwol11
                      My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                      I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                      08-31-2021, 09:32 AM
                    • lp20th
                      Samsung Plasma TV Power Supply Issue
                      by lp20th
                      I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                      11-28-2023, 10:28 AM
                    • mrtek
                      Samsung UN43NU6950FXZA No power
                      by mrtek
                      Hi
                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                      Main fuse = OK
                      Back light LED = OK. Power them with aux power source
                      LED output = OK 156V
                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                      07-20-2025, 08:06 PM
