toshiba 40l1354b
  • Tony g
    • Jan 2022
    • 13
    toshiba 40l1354b
    Hi
    1st of all thankyou for any advise going forward, I really appreciate any help and taking your time to answer.
    I have the above lcd tv, and currently having issues with it switching on.
    When powering up, the power indicator blinks red/green 3 times then pauses then blinks again about 5 times then goes a solid green.
    Nothing on the screen...totally black.
    Any help would be much appreciated.
    I,ve searched for a couple of days for the wiring diagrams, nothing found, but alot of issues by other people pointed me here...
    Thankyou
  • captainKKK
    • Sep 2018
    • 287
    Re: toshiba 40l1354b
    What does the "flash light" test show?
    • Tony g
      • Jan 2022
      • 13
      Hi thanks for the reply..
      I carnt find the flash fault codes anywhere relevant to this model.
      I've looked everywhere..
      Or do you think it might be a generic flash code for all toshiba,s.
      Cheers
      • dskall
        • Oct 2016
        • 2905
        • usa
        Does it have backlights? Image on screen using torch using "UK terms" ?
        • Tony g
          • Jan 2022
          • 13
          Hi
          Thanks again,
          Yes got a faint picture using a torch
          Cheers
          • Tony g
            • Jan 2022
            • 13
            But no back lights..
            Thanks again
            • dskall
              • Oct 2016
              • 2905
              • usa
              A wild guess would be you have some bad led's.
              • neilc6
                • Nov 2015
                • 1550
                TV turning on with no backlights is a sign of bad backlights. Replace them all with new since they wear and burn out just like light bulbs. On Toshibas, bad backlights can also damage the power supply (seen this at least twice). If both are damaged, replacing both power supply and backlights could cost more than the TV is worth. If you are lucky, a LED could have failed open circuit which would act like a fuse and protect the power supply.
                • Tony g
                  • Jan 2022
                  • 13
                  Hi
                  Thanks for the info.
                  Had it a few years now, but broke just after the warrantee, so thought about it as a project, as its immaculate.
                  Just ordered a led tester and i,'ll keep you updated and thanks again for taking the time to help..much appreciated
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    i repaird one of these sets a while ago the full led strip kit was about £30.00 from china takes about 4 weeks for delivery you will need to strip the panel and find what strip numbers this set uses.
                    • Tony g
                      • Jan 2022
                      • 13
                      Hi
                      Will do and thanks, I might look into making a led tester.
                      Any idea where I can get schematics of the power board, ie correct voltage etc.
                      Thanks in advance
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        What power supply number is used in your TV i think it maybe a 17PW07 2
                        Common issue sometimes with these Panels is the little connector blocks that link the Led strings break down and fail so you need to bridge them over with solid wire and then test the Leds
                        • Tony g
                          • Jan 2022
                          • 13
                          Hi
                          Yes 17PW07 v2
                          Looked at eBay, and there selling from £16 - £30
                          But I don't really like buying this sort of thing off there as your taking a risk of buying another faulty board, so would rather go down to component level and fix it myself.
                          As it's a nightmare getting your money back.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            more than likely you will find its a failed led or connection joint have you stripped a lcd panel down before?
                            • lotas
                              • Jan 2016
                              • 4453
                              • Russia
                              Usually the blinking LEDs (red / green) on the Vestel platform is due to a firmware failure.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                he can see a image with a torch he mentioned earlier i think.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  Originally posted by Tony g
                                  Hi
                                  Thanks again,
                                  Cheers
                                  please confirm you can see the no signal screen ot menu screen using a torch
                                  • Tony g
                                    • Jan 2022
                                    • 13
                                    Hi
                                    No I haven't, but I,m can hold my own in electronics,as I fix gaming consoles,laptops,white goods etc, and I'm a electrical engineer by trade, so it will be a good learning curve.
                                    It doesn't phase me, and I'm quite looking forward to it,
                                    As a kid I was really into electronics, but haven't used it for a while.
                                    I'm used to million pound pieces of kit in food factories, safety circuits and motors and such like, so it it,'ll be a wander down memory lane.
                                    • Tony g
                                      • Jan 2022
                                      • 13
                                      Yes there is an image on the screen using a torch..
                                      • Tony g
                                        • Jan 2022
                                        • 13
                                        But I've never ventured into tv's, as its considered a throw away commodity.
                                        But I think I need to stretch the grey matter and give myself a project.
                                        So a bit green around the gills on this subject..
                                        Thanks so much for all your inputs, it's much appreciated.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
