Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Has anyone seen a Sony 55X900C led strip do this?
  • jb_Bak
    • Sep 2021
    • 6
    The LED light strip along the bottom is randomly flashing off about 10-15 leds in a row. Maybe a bad led driver board? Or maybe some strange HDMI switching issue? Seems to get worse once the TV is on for a few minutes.
    Video link here:
    https://youtu.be/HiTvCx_mkkY
  • neilc6
    • Nov 2015
    • 1550
    Re: Has anyone seen a Sony 55X900C led strip do this?
    Edge lits are typically wired in banks. One intermittent in a bank can cause that section to go out. You can lower the backlight level to see if it gets better but you should replace them all with new. LEDs wear and burn out just like light bulbs and your first suspect with backlight issues.
    • jb_Bak
      • Sep 2021
      • 6
      Thank you good idea lowering the backlight level
      • neilc6
        • Nov 2015
        • 1550
        Sonys typically don't have a backlight setting but backlight level appears to be set in the brightness setting. Most backlight failures I have seen in Sonys comes from putting the picture mode to Vivid which runs them at max.
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • NXTPRO
          Sony Bravia KD-55X8000G stuck at Sony Logo
          by NXTPRO
          My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
          Board: 1-982-454-51
          04-03-2026, 07:28 PM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
        • Boardview and Schematic Bot
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          by Boardview and Schematic Bot
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
