Sony 55X900E no standby light, no power. Replaced mainboard already
  • noinimod
    • May 2020
    No standby red light, nothing
    This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
    Disconnected JK3 power board from main board, checked voltages on all the pin outs
    At a few pins I can see the power supply providing 19.5V to the main board
    Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
    LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard, since i've read previous posts stating it's this).
    Some more questions
    1. Does the 12v supply to TCON only turn on when the power button is pressed on? Though i pressed the physical power button and could not see any voltage on the TCON pins (on the JK3 power board)
    2. I can’t find the standby power pin on the JK3 board power diagram. None of the power supply pins give a 3.3V / 5V output. Not sure if this is the problem
    Which brings me to.. it seems strange that there’s 19.5V output to main board, but no 3.3/5V output
    4. Have already swapped the main board, but doesn’t seem to work. I bought from a reputable seller with good feedback from other buyers, but still can’t rule out the replacement mainboard is faulty
    I attached more pictures below with details, hope to learn more from all of you. Is there anything else I should check? Thanks in advance
    I extracted the diagrams from the service manual, link below:
    https://cdn.badcaps-static.com/pdfs/...a35a4a7998.pdf
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony 55X900E no standby light, no power. Replaced mainboard already
    Can we get good picture of board? Your replacement board had exact same problem? If so you may need to load your power supply and make sure it supplies under load.
    • lasantha93
      • Jan 2024
      • Singapore
      Hi All,
      I have the same issue as mentioned above.
      I am also getting about 19.5 in CN9000 left and right pins. To be clear with the flow does 12V send to TCON (from JK3) board only when TURN ON the TV ? (I saw turn on switch is connected to motherboard and motherboard send signal to jk3 to turn on tcon so that it can send 12 V)
      Does anyone have schematc diagram for jk3 board so we can check load under each ?
      I saw there is a IC (ACTN 7D14) in jk3. Does anyone got datasheet for this ?
      Thanks a lot
        • 12179
        • U.S.
        Originally posted by lasantha93
        Hi All,
        Thanks a lot
        Post good focused pictures of each board and one of the whole back as to see how everything is connected.
        • lasantha93
          • Jan 2024
          • Singapore
          Thanks for you reply.Please find the below photos attched
          1. Back of the TV
          Click image for larger version  Name:	IMG_tv_back.jpg Views:	0 Size:	2.67 MB ID:	3175896
          2.Motherboard
          Click image for larger version  Name:	IMG_B_front.jpg Views:	0 Size:	2.59 MB ID:	3175897
          3.LED Driver board
          Click image for larger version  Name:	IMG_LD30.jpg Views:	0 Size:	3.36 MB ID:	3175898
          4.JK3 Board
          Click image for larger version  Name:	IMG_jk3.jpg Views:	0 Size:	1.22 MB ID:	3175899
          5.Tcon Board
          Click image for larger version  Name:	IMG_tcon.jpg Views:	0 Size:	2.78 MB ID:	3175900
          6. IR Sensor Board
          Click image for larger version  Name:	IMG_IR_Sensor.jpg Views:	0 Size:	874.0 KB ID:	3175901
          7.TSA board
          Click image for larger version  Name:	IMG_TSA.jpg Views:	0 Size:	296.1 KB ID:	3175902
          8. Wifi Module Board
          Click image for larger version  Name:	IMG_smart_core.jpg Views:	0 Size:	598.3 KB ID:	3175906
            • 12179
            • U.S.
            Ok, you say there's 19.5 on the connector at two pins of CN9000 of JK3 board, did you trace that voltage thru the wires out, see if it stops or actually gets to the mainboard. Maybe check all the fuses, some can be very small on sonys, did you check the little white fuse on the led driver board.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • delpiero3
              Sony Vaio SVS MBX-261 board failure
              by delpiero3
              Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
              Nevertheless, let's say, i don't come as a total beginner.
              I have this old laptop, which suit perfectly my needs, with the...
              10-29-2024, 06:16 AM
            • stylishconsultant
              un60j620dafxza - Samsung No Display Problem
              by stylishconsultant
              Hi All,
              Need help.
              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
              09-04-2024, 03:26 AM
