LG Plasma Again
  • cadiman
    • Mar 2010
    • 397
    Re: LG Plasma Again
    When you get a chance list the board part numbers for y, z, and power supply ( on the white sticker on the board) and I will check them against mine. I did find the pdp42v6 on scribd gave great diag for boards with no picture, but you need a scope for it and stated 200mhz or better ( I was looking for this cause I only have a 100mhz)
    Mine does ok most of the time for what I need.
    • NxB
      • Feb 2009
      • 1595
      Re: LG Plasma Again
      Boards are in. YSYS hums, Zsus hums. Still no picture.
      • NxB
        • Feb 2009
        • 1595
        Re: LG Plasma Again
        Is it worth checking under the Ysys IC?
        • NxB
          • Feb 2009
          • 1595
          Re: LG Plasma Again
          yup, i fucking blew that too. now I'm lg expert
          • NxB
            • Feb 2009
            • 1595
            Re: LG Plasma Again
            So no we're back at no image. Vy, Vsetup and Vscw are at around the right values but they seem to oscillate. Like Vscw is 115, 111, 120, 114v, etc. Any ideas.
            • NxB
              • Feb 2009
              • 1595
              #26
              Re: LG Plasma Again
              I swapped everything over to another y board and it fucking overheats.
              but it does show display now.
              • DocMichael
                • May 2011
                #27
                Re: LG Plasma Again
                I'm new to the forum but here is a self repair on a zSUS much like the russian one given earlier in this thread.
                http://teleservice.xooit.fr/t4072-pa...42V6-SONIC.htm
                http://img42.xooimage.com/files/7/9/...89-1bdaa36.jpg
                This is a rebadged LG-42 IISONIC.
                • cadillacman
                  • Feb 2011
                  • 524
                  #28
                  Re: LG Plasma Again
                  os your issue is in the ysustain still.. one board no workee but cool, another board works but runs hot, its in the y i would guess.
                  man, i thought i was the only unlucky one to have an lg nightmare..
                  does your set have smd transistors on the buffer boards off of the ysus? if so it might be worth checking those to make sure they arent shorted and causing repeated failure of your ysus..
                  • cadiman
                    • Mar 2010
                    • 397
                    #29
                    Re: LG Plasma Again
                    When these ipms fail there are almost always other issues and not just ipm failure.
                    Two things must happen for a catastrophy!
                    It happens inside the back of an L/G alot.
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • WiredRacing
                      Trials and Tribulations with M.NT68676.2 LCD Controller board and LVDS Panel
                      by WiredRacing
                      Hey all, want to poke the hive mind here for a technology I must be missing something critical about I can't discern from looking at spec sheets alone.
                      I have an ATGames Legends Pinball machine, the playfield is a 32" LCD Display. I'm trying to attach an LCD controller to it for direct PC access, as others have been successful.
                      The LCD is a SPLENDID CD320B01A-350 (I think it's a custom panel for ATGames as google turns up nothing), which is mated to a HV320FHB-N02 (47-6021088) T-CON board (this is probably the important component anyhow)
                      The LCD...
                      08-31-2021, 09:42 AM
