Hisense H55U7BUK - slow to load image
  • djmka
    • Aug 2021
    • 35
    • England
    I have a Hisense 55" H55U7BUK television which has a very strange issue. When you first turn it on the the Hisense logo page appears as expected, then an image appears with the top 25% of the screen displaying correctly and the remaining 75% as if the T-Con is faulty (i.e. it has vertical lines). The screen then starts to recover the missing 75% line by line, taking a minute or so, until you end up with a great picture (please see attached photos). FYI - I've tried replacing the T-Con board but get the same results.
    Has anyone seen this type of issue before?
  • CapLeaker
    Leaking Member
    • 8325
    Re: Hisense H55U7BUK - slow to load image
    What does the OSD look like?
    • djmka
      • Aug 2021
      • 35
      • England
      It appears the same way (please see attached picture).
      • dskall
        • Oct 2016
        • 2905
        • usa
        Looks like panel problem.
        • djmka
          • Aug 2021
          • 35
          • England
          Would a faulty panel “repair” itself like mine does? I was wondering whether it could be a power issue causing the problem. Are there any tests I can do to identify the root cause of the issue?
          • dskall
            • Oct 2016
            • 2905
            • usa
            Looks like maybe a cof tab issue. Maybe getting poor contact to glass. Squeezing the tab to glass on lower cof tabs to see if you can affect problem.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4456
              • Italy - Milan
              Post picture of the tcon. 4 posts only and not a greeting? Not so well..
              • djmka
                • Aug 2021
                • 35
                • England
                Please accept my sincere apologies if I’ve caused offence. It was not my intention - honestly
                • Diah
                  • Feb 2013
                  • 6435
                  since the t-con are cheap i would suggest you to replace it.. its drop down current at it... later hisense didn't used external t-con because of many fault happened within 4k series
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4456
                    • Italy - Milan
                    my doubt and clue is very faint... taken in to consideration that electrolitics faults are much less common nowadays, but in the small case that a bunch of brands suffers still today of that, an electrolitic that works bad at cold and it works at the same frequency of the vertical of the screen, typically 50/100hz, can shorten the lenght of the disturbance until disappears.. but since the only part affected is the images i had guess it is on the tcon.. can you favourite the photo?
                    • lotas
                      • Jan 2016
                      • 4747
                      • Russia
                      T- CON found on the net for Hisense H55U7BUK.
                      https://www.tvparts.co.uk/lcd-tv-spa...sense-h55u7buk
                      • djmka
                        • Aug 2021
                        • 35
                        • England
                        Thanks you to everyone who has responded so far. I have realised that I should have told you the history of the television first (apologies for not having done so). I bought is as a non-working device. It powered up but showed coloured vertical lines on the screen, some thin, some wide. I know this issue was related to the T-CON so I decided to identify which pins of the LVDS cable were causing the issue. Through a process of trial and error, I masked off some pins and the screen started working properly, albeit with the slow start up issue. Next, I checked the part number of the T-CON only to discover it wasn't the correct one. I ordered a replacement, (funnily enough it was from the supplier that lotas suggested) and when it arrived I installed it without masking off any pins. I got the same vertical lines as before. When I masked off the 4 or so pins, the screen started working (again, albeit with the slow start up).
                        Using either of the T-CONs and the tape, the televison's display is fine once it's been on on for a minute or so. If I power it off and on again the display is perfect immediately. This makes me think that something is taking its time to "warm up" but once it's warm it operates as expected.
                        Could it be a voltage issue on the power supply?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4456
                          • Italy - Milan
                          do this test, at cold tv, warm up the AUO chip N7 with the soldering iron, then turn tv on an tell me..
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            So if you are masking off pins that means you have a panel problem.
                            • Diah
                              • Feb 2013
                              • 6435
                              it could be firmware on T-CON didn't matched main firmware... go to this side PW Hisense1234
                              download firmware lower than yours, i suggest the first version of any J firmware... then downgrade it... remember each time you downgrade or update log in service menu make hard reset ( clear chip )
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4456
                                • Italy - Milan
                                if the problem would be a wrong data in the tcon by changing it the problem disappeared but not, other than this if the previous owner have bought a spare tcon it is because the original problem is another...
                                • djmka
                                  • Aug 2021
                                  • 35
                                  • England
                                  Message for Davi.p - when you say heat up the AUO chip N7 - how long should I leave the soldering iron on it?
                                  • djmka
                                    • Aug 2021
                                    • 35
                                    • England
                                    Issue now resolved. I bought a second t-con from tvparts.co.uk and I’m pleased to say that this one worked. My television is working perfectly now. Thanks to all who contributed.
                                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-12-2024, 02:20 PM
                                      HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                      09-06-2024, 10:56 AM
                                      HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                      HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
