reflectors have fallen in tv lg
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hello i have an lg tv that several reflectors have fallen and i have to stick them
    I would like to ask which glue is considered more suitable for this purpose the B7000 is good?
    and how long I have to let it dry before turning off the TV again
    thanks in advance
  • diif
    • Feb 2014
    • 6978
    • England
    Re: reflectors have fallen in tv lg
    I use 5 second fix, It's UV reactive.
    • lotas
      • Jan 2016
      • 4880
      • Russia
      UV glue
      https://aliexpress.ru/item/330534351...16846fa604b3be
      https://aliexpress.ru/item/329684561...16846fa604b3be
      https://www.youtube.com/watch?v=lar3kdjcV_8
      • Xristakis795
        • Mar 2021
        • 162
        • Greece
        Thank you for the useful information, Mr Liota
        how do we clean the reflector with pure alcohol?
        there is no risk of damaging the plastic;
        In addition, this method is very good, but my product will run out of china to the best in a month.
        While I can find the B7000 now, are you stuck with it except that I will wait for an hour or is it prohibitive?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          you can buy the 5 second glue on ebay or amazon etc b7000 wont work long term (i have tried it once) hence changed too the uv glue also makesure you refit the lenses on the exact marks they fell off (lenses i did had 3 mounting lugs so made it easy to re align them other wise you have bright spots on the screen if you fit them in the wrong position)
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            perfect
            If I only get this product https://www.ebay.co.uk/itm/5-Second-...RoCnfEQAvD_BwE
            because I put the translation from Russian but to be sure the light on the back is enough to stick the reflector it just takes more time than using a regular uv lens;
            and one last thing I reflected it to clean it from the old glue without damaging its plastic
            what material can we use?
            • neilc6
              • Nov 2015
              • 1550
              On these LB/LF series strips, I just replace them all with new. All the lenses are likely loose and need to be aligned perfectly or will cause bright spots. The LEDs all have wear and may fail in the future. If you have the panel off, you don't want to go in there a second time when the LEDs start failing.
              • alfatv
                • Sep 2020
                • 353
                Originally posted by Xristakis795
                B7000 is good?
                Should be good. It's not 5 sec, maybe 1hr.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  perfect
                  yes this is the type i have it works ok
                  • Xristakis795
                    • Mar 2021
                    • 162
                    • Greece
                    and what material is used to clean the old glue from the reflector without damaging the plastic plain alcohol or pure alcohol on a cotton swab?
                    sir vinceroger69
                    • Xristakis795
                      • Mar 2021
                      • 162
                      • Greece
                      sorry and one last thing i forgot to ask
                      can i look at the solder when I glue and illuminate with the ultraviolet lens
                      there is a danger to my eyes and I have to wear sunglasses for example
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        I use a scalpel to remove just a little of the old glue.
                        The UV LED points away from you.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          as diif suggests i just use a scalpel etc too remove the old glue if needed and yes uv points away from you so alls good it does say five seconds i always leave light on each mounting point a bit longer about 15 seconds just to make sure they bond.
                          • Xristakis795
                            • Mar 2021
                            • 162
                            • Greece
                            thanks for your answers
