LG OLED65C9PUA no audio/video after delicate move
  • Xavier847
    • Sep 2016
    • 17
    Re: LG OLED65C9PUA no audio/video after delicate move
    Ok, so I was reading a SONY TCON troubleshooting pdf and came across the advice of loosening the LVDS cable and to "gently rock the cable in and out of the connector" looking for a response. It turned out to be the bottom(closest to the 4 ribbon cables that connect to the panel) LVDS cable that causes the TV to shutdown, so I gently put in one corner and started rocking the other end in and came up with this image below. It's essentially the setup screen squished and repeated 4 times. If I plug that bottom LVDS cable in all the way it immediately shuts down like before.
    • Xavier847
      • Sep 2016
      • 17
      Ok, gently rocking the cable every so slightly has me teetering between having a full screen image with the yellow line or shutting down.
      • Diah
        • Feb 2013
        • 6397
        good try.. but my notice at my post #8 remain in place. as i can see from the photo only (G & B ) working .. no R, hopefully this Red cutoff caused by t_CON not at panel self caused by the transport.
        • Xavier847
          • Sep 2016
          • 17
          In post #8 you said "unless you hit the front of the panel within your transport"
          Is this only G & B symptom indicative of a pressure on the front of the panel with no cracks or marks?
          I had a Google Fiber technician in my house while my OLED TV was in the box lying on the floor and he set his bag on the box. I quickly told him to take it off. The TV was in a Home Depot TV box with padding and a blanket so there's no markings from it, but I'm not sure how much his bag weighed.
          • Diah
            • Feb 2013
            • 6397
            OLED Panel Module very thin, specially the OLED RGB film layer under the protective front glass. most issue got damage at this Film Layer ( broken joint points as they are so many and in micro/nano size) of course with out any remark on the front surface.. but let hopes this not the case and the cutoff of R caused by the original T-CON ,as you said the clips may bad.
            • Xavier847
              • Sep 2016
              • 17
              OK, T-CON board arrives tomorrow. Fingers crossed.
              • Xavier847
                • Sep 2016
                • 17
                Installed T-CON and exact same problem persists. Such a bummer.
                • Diah
                  • Feb 2013
                  • 6397
                  i don't know about yours land.. by if this happened in my land i can reclaim the google worker and let his company recover the lost as they have insurance to worker when they attend customer house. between one OLED like small potato to them.
                  • Xavier847
                    • Sep 2016
                    • 17
                    ya, I opened a ticket with the Google Fiber. It's going to take a bit of time to resolve, especially with the holidays. I'll update as it progresses.
                    Thanks so much for your help. I've seen your posts as I searched the forums for a resolution and prayed that you would respond to my thread when I decided to make it after not finding a direct solution. You're a great help and amazing resource to the forum!
                    • samson7point1@yahoo.com
                      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                      by samson7point1@yahoo.com
                      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                      The player processes the audio signal using two different reference frequencies. The "R"...
                      04-30-2024, 11:22 AM
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                    • dikei
                      China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
                      by dikei
                      Hi guys!
                      I'm new to TV repair and just started looking into troubleshooting guides and other online info.
                      Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
                      1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
                      2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
                      From my initial research...
                      07-06-2023, 11:53 AM
                      HP xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation E5450 Specification for Upgrade or Repair
                      This specification for the HP xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                      09-12-2024, 03:36 PM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
