LG OLED65C9PUA no audio/video after delicate move
  • Xavier847
    • Sep 2016
    • 17
    I moved about 2 months ago and am just now getting to troubleshooting my OLED TV. I've owned it for well over a year now and have never had a problem. I bought it lightly used and even moved it across state lines, so I'm confident in the 8 mile move I went through 2 months ago.
    The issue I'm having now is that when I turn it on, there's no audio or video except for quick flash of a vertical yellow line in almost the exact center when turned on. I can hear a solenoid like click when I power it on, then after the brief .5 second flash of the vertical line and 5 seconds of no response in either audio or video, I can hear it click off. Then it just repeats from there.
    I've taken the back panel off and tested the voltages on the Power Board. The only thing that seemed out of place was the connector to the Main Board where DRV_ON is reporting a low voltage.
    I've ordered and received the service remote, so I have that to work with, as well as basic electronic skills and plenty of tools. I'm hoping this is a resolvable issue and that the module/screen isn't beyond repair(the vertical line concerns me).
    All responses and aide is greatly appreciated. Thank you.
  • William1967
    • Nov 2017
    • 206
    • Netherlands
    Re: LG OLED65C9PUA no audio/video after delicate move
    Push the P-Only button on the remote and see what happens.
    • Xavier847
      • Sep 2016
      • 17
      P-ONLY button returns the exact same results as the power button and the symptoms I mentioned before.
      • TeslaMichael
        • Oct 2020
        • 102
        That's sure panel problem. You could remove lvds cable from Mainboard site and try again power only. Maybe it will Start but no Screen or you the line on the screen
        • Xavier847
          • Sep 2016
          • 17
          So, here's some pictures of what I'm dealing with.
          If I unplug the 2 ribbon cables from the mainboard to the T-Con(middle board I'm assuming) board, the image persists on the screen without auto shutting off. So the yellow line persists when all 4 of the bottom ribbon cables are plugged in. The Green banding is what persists when I unplug the outer 2 ribbon cables across the bottom of the T-Con(?) board. The last image shows this scenario.
          Different combinations of bottom ribbon cables give slightly different effects, but generally limit the green banding to the left or right side, sometimes with a reddish hue.
          • Diah
            • Feb 2013
            • 6374
            yours picture
            it show some one work on the LVDS cable before you bought it.. the carton paper glued over the 2 LVDS socket at the T-CON side doesn't belong to this TV at any way..
            so maybe the LVDS cable clips are broken before and they fix the cable with this way... any move ( could be happened by yours move ) the cable sliver pins sitting at wrong place which it will cause shout down.
            inspect them and don't forget to put the other No1 & 4 ribbon cable back between panel module & T-CON driver board.
            • Xavier847
              • Sep 2016
              • 17
              Originally posted by Diah
              yours picture
              Hmmmm, unplugging the LVDS cables prevents it from shutting down but I'm still not getting an image on the screen. Do you think that Vertical Yellow line is indicative a broken panel?
              Do you think I just need to get a new TV?
              • Diah
                • Feb 2013
                • 6374
                OLED. they are micro LED of R/G/B units group.
                from all what i experienced with this module, shorted / defect panel shows one color line or more of one group. Yellow mean the G & B (green -blue )working. also when you turn it on with out LVDS in place the T-CON will not able to refresh all pixel as there no signal command receiving it from main boards.. i would say you have broken LVDS as first suspected because as i mentioned before some one work on them before as yours photo tell this theory.. . take them out and under good loop, inspect them carefully.
                unless you hit the front of the panel within your transport..
                • Xavier847
                  • Sep 2016
                  • 17
                  THANK YOU! I was so careful with moving it that I couldn't believe it was a panel issue. I'll look over the 2 LVDS cables and ports.
                  • Xavier847
                    • Sep 2016
                    • 17
                    So, I took a closer look at the LVDS cables and ports and didn't find anything obviously wrong with either. I'm curious if it could either be the TCON board or the Mainboard that could be the issue.
                    When I moved this time, I left the 2 vertical VESA mounts attached and used those those to handle the TV most of the time because I thought they were the most secure anchor points on the panel. I'm wondering if handling it from there might have caused any issue.
                    • Diah
                      • Feb 2013
                      • 6374
                      So, I'm curious if it could either be the TCON board or the Mainboard that could be the issue. I'm wondering if handling it from there might have caused any issue.
                      you can narrow the issue by this test,
                      1- all cable should be in place as it should.
                      2- only disconnect the 22-24V socket from power boards to T-CON driver board
                      3-turn on the tv ( i think it will run... only black screen... notice the red color indicator o the OPtic audio output socket on the mainboard.. its on meen the TV running. so if it on... give time 2-3 minute running... then while its on plug back the socket mentioned in point 2.. the screen will come on and will show you if the picture complete clear or it had issue.
                      • 27grains
                        • Feb 2021
                        • 18
                        Where does one buy an LG service remote and Schema?
                        Thank You
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          Thank You
                          lg service remote you can buy from ebay or ali express
                          • Xavier847
                            • Sep 2016
                            • 17
                            Ok, so I followed these instructions and on step 3 it powered on with a black screen, red light in the optical port. I tried getting sound from the HDMI1 port with my PS5 plugged in but no audio at all. Then when I plugged the 22V cable back into the TCON board the Yellow line flickered and then the TV shut off.
                            Does this mean that the Mainboard is working and the TCON board is broken? If so, can I replace just the TCON board?
                            • Diah
                              • Feb 2013
                              • 6374
                              okay.. it mean yours Main board working ( optic socket on ).. and the T-CON not the causer of shutdown.. now as the T-CON connect to main board and to the Panel module we can reset it to let all start script and pixel refresh command to be send to the module.
                              as above ( you did before ) turn on the TV with out the socket of 22V connected to the T-CON. wait until you have the optic audio on. with yours LG service RC send command IN_STOP wait the set should after while go to standby as reboot... if it doesn't try again after sending IN_STOP followed with 0 4 3 1.
                              if its reboot wait at least 3-4 minutes after the optic audio goes on ... plug back the socket of 22V .. hope you will be able to see first install image.. if the yellow line remain and cause shutting down... try with finger clicking soft on the area where the line appears and turn on.. notice any change or some time it can solve the short on the panel.
                              • Xavier847
                                • Sep 2016
                                • 17
                                Ok, I was able to get IN_STOP to factory reset the TV with 0413 code. When I turn it back on without the 22V TCON connection, I get the audio for the setup menu "Please press OK wheel button on your remote." When I plug the 22V cable back in, the screen flashes the yellow line and then shuts off. Does this mean the module/panel is bad?
                                EDIT: With everything plugged in except the LVDS cables, I'm able to get the setup audio "Please press OK wheel..." as well as the vertical yellow line to stay on the TV. I tried pressing around the perimeter of the TV near the top and bottom of the vertical line and there was no change in the image.
                                • Diah
                                  • Feb 2013
                                  • 6374
                                  i would say, first invest little on replacement T-CON before you go to sell it as parts.
                                  • Xavier847
                                    • Sep 2016
                                    • 17
                                    I just read that TCON boards are married to the panel and are not able to be used with other panels. Do you have experience with swapping TCON boards on LG OLEDs?
                                    • Diah
                                      • Feb 2013
                                      • 6374
                                      this is wrong information.... they are not maried LOL... the are divorced LOL
                                      • Xavier847
                                        • Sep 2016
                                        • 17
                                        Cool, I just ordered a TCON board from tvpartstoday.com. I'm thinking this could be the resolution. I'll remove the TCON board this evening and check it out.
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • dikei
                                          China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
                                          by dikei
                                          Hi guys!
                                          I'm new to TV repair and just started looking into troubleshooting guides and other online info.
                                          Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
                                          1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
                                          2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
                                          From my initial research...
                                          07-06-2023, 11:53 AM
                                          HP xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation E5450 Specification for Upgrade or Repair
                                          This specification for the HP xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation boardview and xw8600 Intel Xeon Quad Core 5450 3.00GHz 2GB/500GB No Graphics DVD+/-RW WVST Bus Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                                          09-12-2024, 03:36 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
