RCA RLED6090 backlight goes affter 10 minutes
  • nomoresonys
    • 12274
    • U.S.
    Re: RCA RLED6090 backlight goes affter 10 minutes
    change-out of a couple leds and current mod there, yes everyone knows its best to change all the leds when feasible, he has no customer returns as he explains in the comments: https://www.youtube.com/watch?v=WjkHwfx7hig
    • RinusB
      • Sep 2017
      • 17
      Thanks for replying.
      If you read all the comments you will discover that backlights are not the problem. There are two strings and both the voltage and current read the same.
      Looking at a picture taken of a white screen you will see no darkening anywhere indicating that there is a shorted or burned out led.
      Also,I disconnected all the ribbons that go from T-Con to screen and the TV never turns off the back lights. So the trouble is with the T-Con or LCD panel.
      I am now running only three of the four screen connector ribbons to see if the backlight will go off.
      I might add that the connectors at both ends are very shallow and flimsy. I also noticed pins in one of the connectors that look damaged. Inserting the ribbons is difficult and do not look like they were the correct ones. Must be the cheapest supplier.
      I also noticed that the voltage to the backlights cannot be measured unless the LEDs are actually plugged in. the protection circuit detects the absence and shuts them down.When they go off there is no picture either.
      • nomoresonys
        • 12274
        • U.S.
        Yes pally boy I did read all the comments, this is Anooc7's thread and that's what my post is referring to, GOT IT?
        • RinusB
          • Sep 2017
          • 17
          Got it. Thanks.
          • RinusB
            • Sep 2017
            • 17
            After having no shutdown with the one ribbon disconnected I reconnected it to the T-Con board. Getting it to seat properly or straight for that matter indicates that the connectors are very poor. The connectors on the screen board is just as bad. I observed the spring side (under the ribbon) and saw 4 of those springs sticking out. I noticed that looking into the connector there were dark spots of the missing back springs. As I tried to push them back into place one just broke off. The missing piece of that spring was not to be found so it may have been inside the connector.
            I pushed the ribbon in and made sure it was not all the way in but had good contact. I was also making sure it was straight and not angled.
            So far the TV has been working fine for 4 hrs. I am almost affraid to move.
            • RinusB
              • Sep 2017
              • 17
              At least a bit of progress. Someone posted that in the service mode you cannot set the Panel Brightness as it will not save it. Well, it does save any setting for any mode as long as you are in that mode when you start the service menu.
              Menu-1-1-4-7 while the TV is on. To save that setting, turn off the TV and restart it.
              After you have set it lower you have changed the default brightness for that mode but not the back light.
              I believe that back lights are circuit design issues.
              Indeed in ECO mode my TV runs forever.
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • cheebster
                iPad Pro 12.9 5th Gen Backlight Issue
                by cheebster
                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                Anyone...
                05-20-2025, 09:17 AM
              • triplefour
                TCL 75S421 has sound but no backlight not even a flash
                by triplefour
                TCL 75S421
                PSU BOARD: 40-L402H8-PWD1CG
                it shows not even a flash of backlight when powering up.
                but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                with mb connected, PSON...
                11-17-2023, 09:54 PM
