Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #361
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    Hehe .
    This story never ends.. unbelievable
    OK, I will rip ALL Tabs on the same side - You agree ?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4312
      • Italy - Milan
      #362
      sure
      • Ancient1
        • Dec 2019
        • 275
        • Israel
        #363
        smartphone photos look darker than the image on screen is actually is.
        I did not edit ( changed brightness )
        looks great
        Can we say FIXED ?
        What a story !
        • vinceroger69
          • Mar 2012
          • 6714
          #364
          It may of took a while to get too this point but yes a really good picture now, its actually been a interesting fault finding thread, with a good outcome.
            • 12132
            • U.S.
            #365
            ok, so it looks like the problem was a bad powerboard and bad panel, "fixed" by tab removal, needed good powerboard to see the tell tale horizontal lines of the bad panel.
            • Ancient1
              • Dec 2019
              • 275
              • Israel
              #366
              Exactly. PSU died when trying to check results of 1 Tab removal.
              New PSU showed the result isn't good : lines , lighter shade strip were the Tab was ripped , and dark middle screen.
              I Verified the horizontal lines are no more, by using Paint with different full area colors, dark colors, light colors.. No Lines.
              Davi.P : How come the image seem fine with one side without Side Tabs ? Is there any degradation I don't notice ? It is important to me as I plan to put it on sale.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4312
                • Italy - Milan
                #367
                The degradation can be showed mainly right after the removal but stories here in the forum tells that there aren't with time passing, i would be quite curious to see if a 4 ohm resistor could cure the original power board..
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  #368
                  I don't understand : do you mean that the TV will be OK for a long time ? i.e stay fixed and image not deteriorating/degrading for years ?
                  I attach a photo of the Resistor in the new board : I can't find its value ! First strip can not be black ??!!?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4312
                    • Italy - Milan
                    #369
                    i mean that probably will last long, if no other power surges happens..
                    if second band is violet that is a 0,75ohm, if it's blue is a 0,65ohm
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #370
                      I will tell buyer to use Surge Protector.
                      The band is Violet : 0.75 Ohm . I can't get logical reading now.
                      Do you want me to try 4 Ohm on the old PSU ?
                      • lotas
                        • Jan 2016
                        • 4571
                        • Russia
                        #371
                        Why, where did you get the idea that the resistor is 4 ohm.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4312
                          • Italy - Milan
                          #372
                          I told 4 ohm because you said 4ohm before, but no you must use 0,75ohm..
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #373
                            The 3 R I bought , measure in series 1.1-1.2 with my DMM.
                            I will try this , as I assume my DMM isn't precise
                            we'll see
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4312
                              • Italy - Milan
                              #374
                              Your meter probably have a problem in probes or battery, putting 3 0,22 sounds as a waste of time because it's =0,66ohm not 0,75
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                #375
                                Well, you are correct - it didn't work .
                                I does have an issue ! The battery is fine , I replaced not long ago. But the probes don't measure anything sometime
                                I must resolve this.
                                I tried to measure one of the resistors , they have thick, 3.5cm on each side , and I wanted to see the difference between the ends and right next to the actual R ... and I get illogical results, 0.7 ohm and more .. for one !
                                any idea how to investigate the probes ?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4312
                                  • Italy - Milan
                                  #376
                                  i don't understand, are you measuring the R alone or within all the terminals long? which R are you measuring? The 0,22 you bought or the one mounted on the new board? if you are measuring only the terminal 0,7 ohm seems too much.. can you post picture of your meter and probes? Are the probes intact? when you arr measuring little resistors you must subtract the normal value you see by short between probes
                                  • Ancient1
                                    • Dec 2019
                                    • 275
                                    • Israel
                                    #377
                                    I tried measuring again , and the readings are "all over" and illogical even if I hold the probes steady with no movement.
                                    I'll re-measure the batteries with another DMM
                                    I'll de-solder the probes and use something else
                                    by the way , do you see anything unusual in the IC from the 12V PSU ?
                                    I'm going to order it anyway, since I can't find any bad component
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4312
                                      • Italy - Milan
                                      #378
                                      Please don't shuffle things, the other psu in another thread..
                                      • viewerau
                                        • May 2020
                                        • 305
                                        So, if I have this right, if you had initially ripped all those cofs off of the one side, and done nothing else, your problem would have resolved?
                                        Signature:Seemingly hopeless tv fixer
                                        • Ancient1
                                          • Dec 2019
                                          • 275
                                          • Israel
                                          #380
                                          Yes.
                                          But this is one from the "nothing to lose" list.
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
