Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #201
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    It isn't possible to make a mistake with the AZ431 placement , there is a mark on the board with the flat-curve shape of a transistor.
    With regard to NCP1653, I searched ALL the stuff I have and didn't find another, so for now , I will solder new, but lower Wattage R37 5.6K that I found - with big solder blobs to serve as heatsinks, maybe even tiny copper plate to each side. we'll see.
    I will test in auto-start mode of course.
    • Ancient1
      • Dec 2019
      • 275
      • Israel
      #202
      R37 replaced . measures ~5.6k Ohm in-circuit.
      PSU powered : 5VSB = 5.2V
      PSU Auto-Started : 5V pin = 300mV. 12V Pin = GND . SHORT ( I didn't realize that before ). No High V
      IC3
      Pin12 VCC = 6.24V
      Pin16 Vboot = 6.04
      IC2 - See Image
      • lotas
        • Jan 2016
        • 4589
        • Russia
        #203
        Ncp1653
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4322
          • Italy - Milan
          #204
          test pin 1 Q10, test in diode mode all big diodes on cold side
          • Ancient1
            • Dec 2019
            • 275
            • Israel
            #205
            Originally posted by lotas
            Ncp1653
            What does hysteresis mean in regard to measuring ?
            Davi.p : I already did measure Diodes but will do again.
            and measure Pin1 of Q10
            • Ancient1
              • Dec 2019
              • 275
              • Israel
              #206
              Check this out
              D13
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4322
                • Italy - Milan
                #207
                i tell you big double diodes, them have 3 inline pins under heat sink
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  #208
                  OK. will do.
                  Do you think I should check D13 Diode Out-Of-Circuit ?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4322
                    • Italy - Milan
                    #209
                    i don't think you must focus on them, so you measure short on 12v output? also with ohmmeter? I don't understand which influence can do the pfc circuit (ic2) with standby ps, this is very obscure.. with psu auto started check tension on the bigger electrolitics hot side, check also ic2 pin4 to gnd in ohm..
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #210
                      D13 , a W1 diode ( zener ?) on Cold side : I see V in both directions , unlike the others nearby. Looks like D13 is bad and I need to find replacement. see last Photo
                      Measuring resistance in cold PSU :
                      12V : ~2K Ohm . rising
                      5V : 19.6M Ohm . stable
                      5VSB : ~2.5K Ohm. rising
                      PS : 4.4M Ohm . stable
                      IC2 Pin4 (CS) to Pin6 (GND) : 5.6K . stable
                      Big Capacitors : you mean the Main Capacitors :
                      This is standard check. I measured now, PSU Auto-Started : 308V
                      Now I plan to test the Components under the heatsink on Cold side
                      • Ancient1
                        • Dec 2019
                        • 275
                        • Israel
                        #211
                        Heatsink out
                        2 x 60FCT
                        2 x 100FCT
                        Any special way to check these Schottky ?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4322
                          • Italy - Milan
                          #212
                          The PFC is not working, this because its vcc is below 8,5v, i told you to measure pin1 q10, i guess it's a bit low, test also pin2, if it's around 4,9v then remove ic2 and test again pin1&2... the idea to remove heatsink is not good because there's no short in the output, forget D13 for now, it is good until you don't test it outside and it's almost 100% ok
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #213
                            IC2 is PFC circuit. you say its Vcc is below 8.5V = too low ?
                            report Pin1 Q10 Voltage, and Pin 2 & if it is ~4.9V - remove IC2 and measure them again.
                            I'm sorry, but I can't find q10 ? where is it ?
                            I will solder the heatsink back for testing.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4322
                              • Italy - Milan
                              #214
                              fisrt qst: yes. Check post #165 to find q10
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                #215
                                IC2 is PFC circuit. you say its Vcc is 4.98 below 8.5V = too low ?
                                report Pin1 Q10 Voltage 11V, and Pin 2 10.9V & if it is ~4.9V - remove IC2 and measure them again.
                                So, Q10 looks OK , but IC2 Vcc is very low
                                I uploaded IC2 Vcc test to be sure I did not make a mistake in the pins
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4322
                                  • Italy - Milan
                                  #216
                                  Where it is the fast reply box??
                                  Check the path from q10 to ic2, so D6, Q11, ZD3, R81..
                                  • Ancient1
                                    • Dec 2019
                                    • 275
                                    • Israel
                                    #217
                                    what ?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4322
                                      • Italy - Milan
                                      #218
                                      was a message to the staff mainly, don't worry
                                      • Ancient1
                                        • Dec 2019
                                        • 275
                                        • Israel
                                        #219
                                        See Photo
                                        Q11 is a transistor
                                        Resistors near IC2 are OK
                                        • Diah
                                          • Feb 2013
                                          • 6364
                                          wow so long threat... you are swiming against the wave...
                                          yours OP photo and this too
                                          yours issue at LEDs back light or at the LED driver baords.. strip the screen out of the set the set will boot with out screen ...and you will see the shadow where it come from.
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
