Can you dignose from the photo ? . Toshiba 65S2650EV
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4343
    • Italy - Milan
    #161
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    I made a mistake watching the pins because under side photo is mirrored, so the test become so:
    Test in volt on the IC3 pin12 with psu alone.. try also to jumper PS with to gnd and test again IC3 pin12
    the red glue doesn't matter..
    • Ancient1
      • Dec 2019
      • 275
      • Israel
      #162
      I am just curious about that red .. paint ?
      I can check Pin 12 V with PSU alone, in standby of course. This means the IC gets VCC ( maybe not proper V
      than you suggest I short PS pin to GND ? directly or with 1kOhm ? and check #12 again . Like, sounds a bit strange to short PS Pin to GND . Is this is like the ON signal ? because as I understand, if PS is PSU-On line it should get Voltage, not GND
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4343
        • Italy - Milan
        #163
        Red thing is glue as i said. Since PS is not gnd with PSU alone then is pull-up-ed by a resistor to 5v somewhere, so no need for resistor..
        • Ancient1
          • Dec 2019
          • 275
          • Israel
          #164
          In both states , #Pin12 ( vs #Pin10 ) I measure ~20mV .
          PS Line was shorted with GND Line
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4343
            • Italy - Milan
            #165
            in both states you mean with/without jumper on PS pin?
            So you know now why the main smps doesn't turn on, both main smps and pfc ic are not fed, now i want you to force its feeding, watch the poor picture below.. i've marked UF1 the turn on command optocoupler, first try to short it's primary side pins, this puts the Q10 base to low (it's probably a PNP) and making primary vcc rail goes to the said 2 ic, then check outputs, if there aren't, check tension on pin 1 of q10, it must be something around 12v-16v, now you can also short pin 1-2 (collector-emitter), check pin12 of ic3 again and check outputs..(12v-led-out)
            • Ancient1
              • Dec 2019
              • 275
              • Israel
              #166
              "in both states you mean with/without jumper on PS pin?" - Yes. of course.
              Just a quick note :
              I do have ~290V on Main Caps so I think PFC is powered ? and I do have 5.2V on 5VSB.
              And ~2V on PS... this is suspicious as I did see previously 1.35V , maybe because Main is not connected.
              Backlight LED output is 24V . Mainboard gets 12V. different connectors.
              * From what you say , it is obvious that you focus in the Q10 transistor : I will take it out and test it.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4343
                • Italy - Milan
                #167
                i was happier if you did what i had suggested, the pfc is on when you get about 400v on big caps
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  #168
                  OK
                  I want to write what I understand the steps are :
                  1. Connect Opto.HotSide Pins
                  2. Check Pin12 on IC3
                  3. No VCC ? -> Check Q10 Pin1 ( as you marked ) : If 12-16V ? -> Connect Pin1 and Pin2 ( As you marked ) on Q10
                  4. Do 2. again and Check if Outputs exist ( 12V, 24V)
                  The only thing unclear is " making primary vcc rail goes to the said 2 ic, " , because the smaller IC is IC2 . I assume you mean VCC Rail goes to Pin12 of IC3
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4343
                    • Italy - Milan
                    #169
                    steps are ok, the last question i was meaning that the auxiliary of the standby transformer can provide vcc power to pfc ic and main smps ic (ic2, ic3)
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #170
                      All bad
                      with Pins 1,2 connected , I get fluctuating ~0.6-2.5 on Pin12 and fluctuating to 1.5 on Q10. High V do not exists , 5VSB and PS are as before but a bit lower and not stable.
                      I verified continuity after jumpering, and separation to pin #3.
                      Uff .. TV from Hell
                      Can I use another PSU to provide 12V and 24V ? might be different GND .. I think I can find a TV PSU board than does provide those and jumpstart it with this PSU.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4343
                        • Italy - Milan
                        #171
                        I guess there is a problem in the standby stage, the output doesn't support the load, changing PSU is not an option as you said, you could lost time in tests, you have only to correct the feedback items, then locate and change the TL431 chip under the heat sink, is type To92 package, near the border of board, if it isn't enough change optocoupler U1
                        • Ancient1
                          • Dec 2019
                          • 275
                          • Israel
                          #172
                          All this is on the boundary of my understanding, since I know very roughly how a PSU works.
                          I assume by "feedback" ( you have only to correct the feedback items ) you mean the Opto which, being triggered by the PSU-On signal opens Q10 transistor to power IC3.
                          I see 3 AZ431 Transistors near the heatsink on the Cold Side. But TL431 ?
                          Is it a Standby PSU issue or signal issue ? because if the Standby PSU isn't working properly than perhaps the area near the small , yellow , coil should be investigated ?
                          I forgot to upload Q10 photo, so here it is : A684
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4343
                            • Italy - Milan
                            #173
                            These are the two that must be changed, AZ431 is the same as TL431, them are IC:
                            • Ancient1
                              • Dec 2019
                              • 275
                              • Israel
                              #174
                              You mean "replace" , yes ? put new of the same
                              I can test & compare 2 of the AZ431 . How about testing the Mosfets under the big heatsink on the cold side ?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4343
                                • Italy - Milan
                                #175
                                you can compare but it's a bit time consuming, replace them and stop
                                • Ancient1
                                  • Dec 2019
                                  • 275
                                  • Israel
                                  #176
                                  found : ( each line one board )
                                  AS431 , PC123
                                  431A , NEC 2561A
                                  AZ431 , EL 817
                                  TL431 & KA 431AZ , PC817 & cosmo 1010 PC817
                                  our board :
                                  AZ431 , 817c
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4343
                                    • Italy - Milan
                                    #177
                                    i don't understand this message.. i have said to you which one to change..
                                    i have forgot one reply, for change i mean replace..
                                    • Ancient1
                                      • Dec 2019
                                      • 275
                                      • Israel
                                      #178
                                      I have 4 bad PSU boards , and I list what they have.
                                      I assume any 431 and any 817C will be good replacement ?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4343
                                        • Italy - Milan
                                        #179
                                        yes, pc123 and 817 the same
                                        • Ancient1
                                          • Dec 2019
                                          • 275
                                          • Israel
                                          #180
                                          OK :
                                          Replaced with AS431 , PC123 .
                                          Tested in TV : same as before - Red LED does not go dark . No BL nothing.
                                          BUT
                                          Measured PSU alone :
                                          1. IC3 Pin12 = 9.8V !
                                          2. Q10 : #1 = 13.57 ; #2 = 13.25 ; #3 = 12.6 . ( #Pin as you wrote ).
                                          3. Opto.ColdSide = 1.12V
                                          So you were again correct : replacing on Cold Side made a big change.
                                          Isn't Pin12, Vcc, too much ? Specs say it can take up to 20V
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
