Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #61
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    Did one more time : removed the Rosin ( flux) with IPA. No solder to wick so I went with a needle over the thin border between those TPs.
    Nothing else I can do
    • Ancient1
      • Dec 2019
      • 275
      • Israel
      #62
      I did it one last time
      cleaned the Rosin and since there is no Solder to clean out , I went with a needle point on the fine line between those 2 TPs.
      Really nothing more I can do. Still, maybe there is . I don't want to smell a burning IC :/ .
      If I don't come up with a new idea, I will put the Panel back tomorrow.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4347
        • Italy - Milan
        #63
        so those 2 TP are different signals? can you show me which are in your past photo?
        • Ancient1
          • Dec 2019
          • 275
          • Israel
          #64
          The photo is of the other side Tab. I soldered Proper Left side , near the VGH VGL TPs (only) on the Distribution board. But the position is correct : Model Number side and TP order/position.
          Unfortunately I find it practically impossible to take close-up photos. But trust me , there is no more solder to remove. I assume what is left is stuck to the silver paint.
          And as I said before : the same ones on the other side are naturally shorted.
          Both with 0V
          • Ancient1
            • Dec 2019
            • 275
            • Israel
            #65
            sometimes I can, sometimes I can't edit.
            Anyway , managed to take clearer photos ( using 2 magnifying lenses )
            • Ancient1
              • Dec 2019
              • 275
              • Israel
              #66
              Tested
              No Logo :/
              Re-inserted the Flex/s
              Logo : No short
              But : same image defects
              I will measure the Side Tabs again , perhaps another line needs repair
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4347
                • Italy - Milan
                #67
                Stop. Have you ever tested the backlight with no lcd panel in front? Maybe i remember a far case where leds had a strange misunformity...
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  #68
                  Well , the BL is new set. I do notice circles : probably the diffusers are too close ( or LEDs too bright ? )
                  These horizontal grayish areas .. I don't think they are BL related but I'm willing to test : suggestions ?
                  There is also a horizontal line
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4347
                    • Italy - Milan
                    #69
                    Which type of backlight has? Full led or edge led? if you can turn on tv and lift the panel you see if BL is uniform
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #70
                      Vertical LED strips , 12.
                      Checking visually is not a problem, I think I need to measure TPs again , now that VGH is present
                      • Ancient1
                        • Dec 2019
                        • 275
                        • Israel
                        #71
                        UFFFF I come to measure the Tabs - and there is no Logo. Half Logo when Left ( VGH bypass) Flex is disconnected.
                        UFFF
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4347
                          • Italy - Milan
                          #72
                          but which are the measurements now? 'Sorry i don't have checked your last photos well, i considered that an easy job theorically speaking, but i have seen that you soldered the wire in the wrong tp of the tab.. if you watch your photos you have solderer vgh line onto vgl testpoints doing a short circuit, internal ones are vgl tp, external one are mixed vgh+vgl tp..
                          • Ancient1
                            • Dec 2019
                            • 275
                            • Israel
                            #73
                            I didn't measure yet because I am pissed off . I will tomorrow
                            The photo is one good photo I managed to take. So it fits either Left or Right ( forgot) .
                            What matters is the #Model side and inner or outer.
                            I soldered the mirror TP of the one with VGH
                            I doubt I made a mistake, especially since I measured continuity to every TP around it.
                            We'll see
                            Thx
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4347
                              • Italy - Milan
                              #74
                              You don't understand maybe, continuity doesn't apply , the vgh tp is outer respect to the panel, your soldering is inner, it's easy...
                              • Ancient1
                                • Dec 2019
                                • 275
                                • Israel
                                #75
                                ok. I will test Right side for VGH ( I soldered Left ). We'll see if it is inner or outer.
                                • Ancient1
                                  • Dec 2019
                                  • 275
                                  • Israel
                                  #76
                                  Hi
                                  You must be right since when I measured the Right Tab with BOTH Flex connected ( No image at all , no Logo or [not connected] ) : I didn't find VGH Voltage Nor -7.7V , just mV .
                                  When I disconnected Left Flex , I found VGH ( 25.5V YELLOW) TP, and VGL ( -7.7 GRAY) TP.
                                  The image is a short version of the tab : three double TP are nearest to IC from both halves.
                                  The image can, in fact, be called Left Tab since I soldered to the VGH TP as seen : closest to Board and the #Model half of the Tab.
                                  So obviously I am doing something wrong ! but what
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4347
                                    • Italy - Milan
                                    #77
                                    You are not following me, check post #41 your 1st photo, you see by yourself that's this last draw is wrong, this shows what you think you have been but VGH TP is not there.. it is under.. repeat, outer *respect* to the panel glass not the pcb..
                                    you solfered on 2, VGH is on 1...
                                    • Ancient1
                                      • Dec 2019
                                      • 275
                                      • Israel
                                      #78
                                      Oh wow
                                      You can see how in the Right half of the Tab ( #Model) VGH is INNER (to the Panel) and in the Left side ( Manufacturer ) it is OUTER.
                                      I will check again because it gets me confused.
                                      When I measured Voltages I couldn't remember even 2 readings , had to re-measure to write down correctly. very strange, now this.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4347
                                        • Italy - Milan
                                        #79
                                        ok you are right, sorry..
                                        • Ancient1
                                          • Dec 2019
                                          • 275
                                          • Israel
                                          #80
                                          I will disconnect the VGH TP on the BOARD. See what happens.
                                          I will re-measure both TABs.
                                          Obviously with the VGH bypass , things are worse.
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
