JVC 49cf890 - Fire TV - no picture but sound
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: JVC 49cf890 - Fire TV - no picture but sound
    This is just a hobby for me. So there is no fun for me in board swapping. But I understand others are here just to find out what board to replace to get their TV's working again.
    • vinceroger69
      • Mar 2012
      • 6714
      same as me then, just a hobby i also like saving stuff from landfills any repaired items i pass on to family or freinds and just charge them for any parts ive had too buy.
      • Dobsuk
        • May 2020
        • 127
        • England
        So, it is not the main board The new one arrived yesterday but it is still the same.
        • Dobsuk
          • May 2020
          • 127
          • England
          post 2 picture 3 under the ribbon cable connector there is a fuse marked N what votage do you get on each side of that one meter lead on metal tv chassis then test voltage each side.
          Will check this when i find some free time
          • vinceroger69
            • Mar 2012
            • 6714
            Im pretty sure you will find its fine though atleast you have ruled a bad mainboard out. So now because you only get a flash of back lights i think that may need to be your next check have you got a back light tester? can you post some good clear pictures of the backlight connector on the power supply as you maybe able too check the voltage there with a multi meter.
            This maybe the schematic for you board but there are a few revisions of this psu
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              From here on out it will likely be component level repair.
              • Dobsuk
                • May 2020
                • 127
                • England
                #27
                Actually i do not get backlight flash only. The backligiht is working and i can see it from the back holes. Unfortuanetlly cannot upload video as this forum does not accept .mp4 video formats. I wll upload clear photo of the backlight connector in few mins....
                • Dobsuk
                  • May 2020
                  • 127
                  • England
                  #28
                  Ok, here we go and some photos of the backlight connector. I believe that should be:
                  I have got -123V on that connector and maybe you can see that the backlight is on.
                  • Dobsuk
                    • May 2020
                    • 127
                    • England
                    #29
                    12.3V both ends on that fuse
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      #30
                      I can feel that part here is getting very hot:
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #31
                        You will need to start checking voltages and for shorts.
                        • Dobsuk
                          • May 2020
                          • 127
                          • England
                          #32
                          I checked all resistors - all looks good except that R100:
                          I have got short both ends. Is that resistors also?
                          Can you advise which voltages i need to check please?
                          Thanks.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            #33
                            Will need good pictures all along board.
                            • lotas
                              • Jan 2016
                              • 4753
                              • Russia
                              #34
                              R100 - 0.1 Om
                              • Dobsuk
                                • May 2020
                                • 127
                                • England
                                #35
                                • lotas
                                  • Jan 2016
                                  • 4753
                                  • Russia
                                  #36
                                  You do not need to check the resistors, but the blocking ceramic capacitors (they should not have low resistance, short circuit). Check what resistance across induktors is relative to gnd.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    #37
                                    Voffe, vone, vcc avvd and test points with voltages marked. All points should have correct voltages. Disconnected those points should not be low ohms from ground to test point.
                                    • lotas
                                      • Jan 2016
                                      • 4753
                                      • Russia
                                      #38
                                      And check the resistance between these induktors and gnd.
                                      • Dobsuk
                                        • May 2020
                                        • 127
                                        • England
                                        #39
                                        Voffe - 0V
                                        Vss - 0V
                                        Cannot find Vone and VCC AVD. Found VONE here but not sure which point to measure:
                                        Also found few Vcc point but not AVD.
                                        On this 32V point i have got 0V
                                        • Dobsuk
                                          • May 2020
                                          • 127
                                          • England
                                          #40
                                          2 of them are giving me aproxx 145Ohms and the other 2 nothing.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • jchang
                                            Samsung UN70NU6900F no picture and no sound
                                            by jchang
                                            Hi all
                                            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                            Symptom:
                                            No picture no sound.
                                            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                            No sound at all.
                                            What I tried:
                                            1. I tried unplugging the left or right ribbon...
                                            01-09-2023, 06:28 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
