Samsung ue49mu6120
This topic is closed.
  • piotr3m
    • Jan 2021
    • 3
    • Poland
    #561
    Hi, could you take a look at this dump?
    It is from ue50ku6000, chip IC1103_SPI
    main bn94-11256D
    No standby diode. Is it something you can fix?
    • lotas
      • Jan 2016
      • 4595
      • Russia
      #562
      main bn94-11256D
      What kind of dump is this, where did you think it was from and why, have you even seen this content in a hex editor, it looks like complete garbage.
      • piotr3m
        • Jan 2021
        • 3
        • Poland
        #563
        Hi, I just read it from the chip. Possibly wrong clamp. I've read it again (twice and compared hashes). Also, chip identificaion worked ok - I hope this one is read fine.
        • lotas
          • Jan 2016
          • 4595
          • Russia
          #564
          This one is completely different, try this one.
          • lotas
            • Jan 2016
            • 4595
            • Russia
            #565
            Or your corrected one.
            • piotr3m
              • Jan 2021
              • 3
              • Poland
              #566
              No luck, unfortunately. I tried both files, verified with reading and checking sha1 that programming was ok. Possibly something else is a problem (eeprom?). Anyway, thank you for checking.
              • sirjoe
                • Aug 2024
                • 8
                • ITALY
                #567
                This suggests that the dump you posted was not original, the dump was not written correctly, or something else was wrong...
                Thanks Iotas for the reply. To be safe I made copies of the original dump with other programs. I attach them even if they seem the same to me
                • lotas
                  • Jan 2016
                  • 4595
                  • Russia
                  #568
                  These dumps are absolutely all the same.The original dump is considered to be the one that was originally there after the TV broke down, if after that they tried to write other people’s dumps there without getting the result, and then read it from the chip, then it will no longer be original.
                  Click image for larger version  Name:	dataurl436581.png Views:	0 Size:	359 Bytes ID:	3451159
                  • sirjoe
                    • Aug 2024
                    • 8
                    • ITALY
                    #569
                    yes of course, the attached dumps were saved before making changes, immediately after opening the tv
                    • lotas
                      • Jan 2016
                      • 4595
                      • Russia
                      #570
                      Write in detail how you recorded the dump, what you did, the procedure.
                      • sirjoe
                        • Aug 2024
                        • 8
                        • ITALY
                        #571
                        I use the ch431 black programmer with clip. After opening the program as administrator, for example NeoProgrammer, I did detect ic and chose w25q40, then read and save.
                        • lotas
                          • Jan 2016
                          • 4595
                          • Russia
                          #572
                          I ask how you recorded my dump, what you did, describe in detail.
                          • sirjoe
                            • Aug 2024
                            • 8
                            • ITALY
                            #573
                            I followed the instructions you gave in previous posts, that is:
                            1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                            2. Click "Unprotect".
                            3. Click "Erase IC" and "Yes".
                            4. Click "Open File" and select your corrected Dump.
                            5. Press "Program IC" and "Yes".
                            6. Click "Verify IC".
                            7. Press the down arrow to the right of "Unprotect" and select "Edition SREG", put a check mark on SRP0+BP1 and CMP+QE and press "Write" and "Yes"​
                            • Martin_CZ
                              • Jan 2021
                              • 9
                              • Czech
                              #574
                              Dear friend, please modify this dumps. Thank You. Martin
                              • lotas
                                • Jan 2016
                                • 4595
                                • Russia
                                #575
                                Yes, everything here is done correctly.
                                • lotas
                                  • Jan 2016
                                  • 4595
                                  • Russia
                                  #576
                                  There are two dumps in the archive, should I fix both?
                                  • lotas
                                    • Jan 2016
                                    • 4595
                                    • Russia
                                    #577
                                    Yes, in my opinion I can’t wait for an answer, I fixed both dumps, try it.
                                    • Martin_CZ
                                      • Jan 2021
                                      • 9
                                      • Czech
                                      #578
                                      Good solution Yes, I need to repair both of dumps in archive. OP 24082904 - already tested and working, but second dump OP 19020603 still not working. Red LED not lit, TV not turn on..
                                      Martin
                                      • lotas
                                        • Jan 2016
                                        • 4595
                                        • Russia
                                        #579
                                        Martin
                                        I corrected both dumps and they are fully working, or I wrote it down incorrectly (didn’t install status registers), or there is another problem somewhere..
                                        • Martin_CZ
                                          • Jan 2021
                                          • 9
                                          • Czech
                                          #580
                                          OK. I used same procedure for programming, verify was OK, so there is possible, that board has a different failure. But voltages are OK and there is no short at board.
                                          Thank You very much for Your time. Martin
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
