Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4708
    • Russia
    #521
    You are doing everything correctly, only the contacts on the chip must be cleaned of flux, rosin, solder residues and the contacts on the block must also be clean...
    • crystalsound
      • 15
      • italy
      #522
      I installed a working mainboard taken from a ue55mu6120k and it's perfectly working without modifying anything, even on the 25q80, nothing. But I'd like to fix the original one. I wrote the original dump I posted here and it used to turn on and off with no video, but now it doesn't boot at all, I don't know if the reason is the dump, which may be corrupted as you suggested, or a matter of register, although I followed your instructions. Isn't there any way to write a "default" firmware for this model? What if someone has a TV with a faulty flash - and therefore with no dump to fix?
      • lotas
        • Jan 2016
        • 4708
        • Russia
        #523
        There is no standard firmware, since it changes when updating the software, the software version 24Q40 must match the eMMC software version, if the standby mode does not appear (STB LED does not light), then the dump is not recorded correctly (status register) and the first time it is turned on, it is damaged again. ..
        The fact that you posted your dump, was it original, native, or was it after experiments, recorded on it without saving its original?
        • lotas
          • Jan 2016
          • 4708
          • Russia
          #524
          I can fix any original dump from this "MU" series or look for a donor (motherboard)...
          • crystalsound
            • 15
            • italy
            #525
            it was definitely original. But the native problem of the tv was not "no standby at all", it was booting with backlight and no image, 4-5 seconds with audio then off and reboot again. I desoldered the 25q40, read it and posted here without doing anything else.
            • jaypay15
              • Aug 2024
              • 6
              #526
              Dear lotas if you could can spare the time to fix the attached bin I would be very grateful.
              Regards Jamie
              • lotas
                • Jan 2016
                • 4708
                • Russia
                #527
                Regards Jamie
                Try.
                • jaypay15
                  • Aug 2024
                  • 6
                  #528
                  Try.
                  Thanks so much I will let you know how it goes.
                  • lotas
                    • Jan 2016
                    • 4708
                    • Russia
                    #529
                    Ok. Don't forget about the register status...
                    • jaypay15
                      • Aug 2024
                      • 6
                      #530
                      I flashed the bin and register value but the TV is still dead. I read the chip back and the bin was intact. Thanks for your time.
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        #531
                        It’s strange, but everything should have worked if everything was done correctly, except that it wouldn’t have hurt...
                        • adiasterix81
                          • Aug 2017
                          • 40
                          • Romania
                          #532
                          can someone check my bin? I dont have the stanby led. TV - Samsung ue49mu6120kxzt - IC1604
                          • lotas
                            • Jan 2016
                            • 4708
                            • Russia
                            #533
                            Here, in my opinion, I didn’t see anyone except me that I could check and correct. Try it.
                            • adiasterix81
                              • Aug 2017
                              • 40
                              • Romania
                              #534
                              Hy. It worked. Thank you. God bless you
                              • lotas
                                • Jan 2016
                                • 4708
                                • Russia
                                #535
                                Ok! Thank you!
                                • sirjoe
                                  • Aug 2024
                                  • 8
                                  • ITALY
                                  #536
                                  Hi, I have a Samsung ue49mu6470 with the stand by LED off problem. The power board works fine as does the panel. I would like to try with the w25q40cl firmware fix.
                                  The model of my TV is
                                  UE49MU6470UXZT
                                  Main Board BN41-02568B / BN94-12399P
                                  I attach the original dump (AsProgrammer)
                                  • lotas
                                    • Jan 2016
                                    • 4708
                                    • Russia
                                    #537
                                    UE49MU6470UXZT
                                    Try it. Change the program to NeoProgrammer V2.2.0.10, it works more correctly than Asprogrammer with status registers settings.
                                    • pellas
                                      • Aug 2024
                                      • 3
                                      • Sweden
                                      #538
                                      Hi, Samsung UE55mu6455 here. Can you have a look at my file please?
                                      • lotas
                                        • Jan 2016
                                        • 4708
                                        • Russia
                                        #539
                                        Hi, I looked, it was damaged, I fixed it, try it.
                                        • pellas
                                          • Aug 2024
                                          • 3
                                          • Sweden
                                          #540
                                          Works! Thanks a lot! I even managed it using the clothespin.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
