Samsung ue49mu6120
This topic is closed.
  • bmt_hr
    • Sep 2012
    • 8
    • Croatia
    #161
    Re: Samsung ue49mu6120
    I have a same problem, no stby...
    Readout of my 25Q40 attached, can it be repaired?
    Thank You!
    • lotas
      • Jan 2016
      • 4818
      • Russia
      #162
      Thank You!
      Try.
      • bmt_hr
        • Sep 2012
        • 8
        • Croatia
        #163
        Originally posted by lotas
        Try.
        It's work fine!!
        Thank You very much!
        • wbudnik14
          • Feb 2023
          • Polska
          #164
          I've got a problem with the IC1604. I see that I've got the first bits but there is a problem with a SREG. Whn I'm trying to prtect 0x88 and 0x42 there is no such a posibility. It's suck on 0x90 and 0x45 and when i'm trying to write it nothing changes. I can change the batch, but can't do anything with SREG. When I'm trying to unprotect blank chip it's stuck on 0x90 and 0x45. Can i do anything with that? Thanks
          • lotas
            • Jan 2016
            • 4818
            • Russia
            #165
            Look for another spi flash, your dump is working.
            ...These checkboxes can be removed from 0x90 and 0x45 and click on Write?
            • wbudnik14
              • Feb 2023
              • Polska
              #166
              Yes and i can't overwrite it. It's still on 0x90 and 0x45. I'm gonna try to change the chip. Thanks
              • Alberto
                • Sep 2015
                • 17
                • Caceres
                #167
                Good morning
                I would greatly appreciate your help to repair this file from a Samsung UE49MU6105K, it doesn't turn on anything, not even standby
                thank you so much
                • lotas
                  • Jan 2016
                  • 4818
                  • Russia
                  #168
                  Originally posted by Alberto
                  Good morning
                  thank you so much
                  Try.
                  • Alberto
                    • Sep 2015
                    • 17
                    • Caceres
                    #169
                    thanks a lot
                    I'll try it on Monday and report the results.
                    • Alberto
                      • Sep 2015
                      • 17
                      • Caceres
                      #170
                      Try.
                      Good morning
                      I've tried the file but unfortunately it doesn't work, I don't have standby, the TV is completely dead.
                      any help please?
                      thank you so much
                      • lotas
                        • Jan 2016
                        • 4818
                        • Russia
                        #171
                        Good morning
                        any help please?
                        thank you so much
                        Did you set and write the correct "status register" (0x88, 0x42) after writing the corrected dump? Most likely, he (dump) again flew off after applying voltage to the board.
                        • Alberto
                          • Sep 2015
                          • 17
                          • Caceres
                          #172
                          Sorry but I don't know how to do it (0x88, 0x42), I have a RT809H programmer.
                          Could you help me do it?
                          thank you
                          • lotas
                            • Jan 2016
                            • 4818
                            • Russia
                            #173
                            thank you
                            After writing my dump and Verify, click on "Protect" and check the boxes as in the photo and click "Write".
                            • Alberto
                              • Sep 2015
                              • 17
                              • Caceres
                              #174
                              Now the standby light is on and it blinks when you press the power button but it does not show any image. The heatsink chip gets very hot.
                              I hope your help
                              thank you
                              • lotas
                                • Jan 2016
                                • 4818
                                • Russia
                                #175
                                I hope your help
                                thank you
                                Well, how can I help you, this behavior can be if someone else's firmware was written into it, from another TV, this dump (the one that you posted it native?
                                • Alberto
                                  • Sep 2015
                                  • 17
                                  • Caceres
                                  #176
                                  The file sent by the original extracted from the television with RT809H there is no doubt.
                                  I hope you can help me
                                  thank you
                                  • lotas
                                    • Jan 2016
                                    • 4818
                                    • Russia
                                    #177
                                    thank you
                                    But this dump is exactly the same as what you posted in #167, well, try again...
                                    • Alberto
                                      • Sep 2015
                                      • 17
                                      • Caceres
                                      #178
                                      correct is the same as the one in post #167, it is the original TV defects.
                                      I try again and confirm
                                      thank you
                                      • Alberto
                                        • Sep 2015
                                        • 17
                                        • Caceres
                                        #179
                                        good afternoon again
                                        Tried again and it still doesn't work. standby light on but nothing on the image.
                                        The file that I send you is the original of the television.
                                        any help to put with a good file
                                        thanks thanks
                                        • lotas
                                          • Jan 2016
                                          • 4818
                                          • Russia
                                          #180
                                          There may be a problem when removing or installing spi flash 25q40, the components moved around this memory (resistors ...), if you used a soldering station with hot air, the flash itself is not working properly, there may be a problem in the T-Con firmware (25Q80), the problem is in panels...
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
