Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4819
    • Russia
    #101
    Re: Samsung ue49mu6120
    Yes, maybe I wrote about this modding somewhere here on the forum, try this one.
    • Yakubusta
      • Nov 2022
      • 19
      • Türkiye
      #102
      I'm sorry, but it still didn't work. 44 is not. Could it be another problem? For example, could my chip or programmer be faulty?
      • lotas
        • Jan 2016
        • 4819
        • Russia
        #103
        Why do you need "Reading" ?, why an empty window ?, You are doing everything wrong.
        I will repeat again:
        1 The chip must be erased from the beginning.
        2 Then flash with my dump - fix.
        3 Then go to "Edition SREG" set the values 88, 42 and click "Record".
        • Yakubusta
          • Nov 2022
          • 19
          • Türkiye
          #104
          First thank you so much for your help. I got new chip today 25q32a model. The problem was old chip. Tv works but now there is a scratch on the screen. How can you help me with this? Thanks.
          • lotas
            • Jan 2016
            • 4819
            • Russia
            #105
            Congratulations, why did they install the 25Q32 chip (32 mega bits (4 megabytes)? At the expense of the strip on the screen, see the cables at the bottom of the screen did not accidentally damage when disassembled, removed the back cover.
            • Yakubusta
              • Nov 2022
              • 19
              • Türkiye
              #106
              Parts are hard to find in Turkey. 25Q40Cl was absent. They said it would be 25q32A. I wrote your software on the new chip and it's fixed. The old one was faulty. because I couldn't throw the software somehow.
              • Crossfader
                • Nov 2022
                • Germanyo
                #107
                Hi, i have the same problems. The TV does not turn on, but when I disconnect the power supply, the leds are on. No Standby LED. Lots of FF in the Hex file.
                TV is an UE49MU6179UXZG
                Mainboard BN41-02568B
                Many thanks
                • lotas
                  • Jan 2016
                  • 4819
                  • Russia
                  #108
                  Many thanks
                  Try.
                  • Crossfader
                    • Nov 2022
                    • Germanyo
                    #109
                    Originally posted by lotas
                    Try.
                    The TV ist starting
                    Only i cant edit the SREG, it was impossiblle to set the Register to 88.
                    Its fix on 00.
                    But i know now thats the tv is working
                    • lotas
                      • Jan 2016
                      • 4819
                      • Russia
                      #110
                      The TV ist starting
                      Its fix on 00.
                      Then do a factory reset through the service menu.
                      • nomoresonys
                        • 12317
                        • U.S.
                        #111
                        can try the tape method for the line, might work: https://www.youtube.com/watch?v=N6nVJja2WxA
                        • lotas
                          • Jan 2016
                          • 4819
                          • Russia
                          #112
                          Why does he need a tape method for the line, if his "standbay" firmware has crashed.
                          • nomoresonys
                            • 12317
                            • U.S.
                            #113
                            the line could be due to a bad component on the panel driver board, check the little ceramic caps for shorts, also check the resistors close to the line, make sure they are ok in tolerance and have good solder joints.
                            • nomoresonys
                              • 12317
                              • U.S.
                              #114
                              Read it Lotus post #104, his chip is fixed, NOW he has a problem with a vertical line.
                              • Damian.bak
                                • Nov 2022
                                • Poland
                                #115
                                Hi, I have the same sympthoms with my TV. The TV does not turn on, but when I disconnect the motherboard from power supply, the backlihgt leds are on. I have read the dump, there are a lot of FFs. Can someone take a look and help with this? Can You also elaborate how to fix the dump?
                                TV model: SAMSUNG UE50MU6172U
                                MOTHERBOARD MODEL: BN41-02568B
                                CHIP : WINDBON 25Q40CLSIP
                                • lotas
                                  • Jan 2016
                                  • 4819
                                  • Russia
                                  #116
                                  Your dump is either poorly read or badly damaged, read it again without any clothespins (unsolder the flash and through the adapter).
                                  • Damian.bak
                                    • Nov 2022
                                    • Poland
                                    #117
                                    You are right, I was using clothespin. After reading I have erase the IC and tried one of Your fixes "BN41-02568B_Fix.bin". I am not sure if it was written succesfully while reading was poor. Anyway I have unsoldered the IC now and read it once again. I hope it did not mixed old dump with Your fix. Please, check it. Meantime I have ordered another motherboard from the same model, but different LCD panel. Can I use that one?
                                    • lotas
                                      • Jan 2016
                                      • 4819
                                      • Russia
                                      #118
                                      With someone else's dump, the TV will not fully start, since each dupm has its own identifier (keys), if you have already erased and written someone else's dump to spi flash without saving your own, it will be difficult to restore, you need to rewrite the entire dumps set on this motherboard (not when not use clothespin).
                                      Your dump has already been overwritten by another dump.
                                      • Damian.bak
                                        • Nov 2022
                                        • Poland
                                        #119
                                        Understood, so I guess this motherboard is a trash?
                                        Will it work with another motherboard? As I said second board is from the same tv model, but different LCD panel.
                                        • lotas
                                          • Jan 2016
                                          • 4819
                                          • Russia
                                          #120
                                          Here, how lucky the T-con settings and the panels are stored in 25q80 (it can be enough to transfer this flash to a new motherboard, and if you look for your panel, you need to call BN94-xxxxxx.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
