Samsung ue49mu6120
This topic is closed.
  • Salvocchio
    • Mar 2024
    • 12
    • Cagliari
    #441
    Sorry Lotas. My programmer is the one in the attached picture. What are the improvements I need to make to make it work better?
    • lotas
      • Jan 2016
      • 4710
      • Russia
      #442
      WARNING: If the /WP or /HOLD pins are tied directly to the power supply or ground during
      standard SPI or Dual SPI operation, the QE bit should never be set to a 1.
      To correct this drawback, you need to disconnect the legs #WP (pin 3) and #HOLD (pin7) from VCC
      and connect them to VCC through 4.7 kohm resistors.​
      • Salvocchio
        • Mar 2024
        • 12
        • Cagliari
        #443
        Basically, should I make the two changes?
        • lotas
          • Jan 2016
          • 4710
          • Russia
          #444
          Yes, above is a diagram with modifications to the power supply (blue, don’t forget about 9 pin) and the addition of resistors.
          • Salvocchio
            • Mar 2024
            • 12
            • Cagliari
            #445
            Some doubts:
            Should C1 and C2 be eliminated, and should the tracks be connected or left open?
            Is there any connection to be broken beyond contact 28 of CH341A ?​
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4430
              • Italy - Milan
              #446
              Country: Cagliari?? Italy...
              • Salvocchio
                • Mar 2024
                • 12
                • Cagliari
                #447
                Yes
                • jellytot
                  • Mar 2015
                  • 42
                  • Ireland
                  #448
                  hello
                  • Salvocchio
                    • Mar 2024
                    • 12
                    • Cagliari
                    #449
                    Originally posted by lotas
                    Yes, above is a diagram with modifications to the power supply (blue, don't forget about 9 pin) and the addition of resistors.
                    Some doubts:
                    • lotas
                      • Jan 2016
                      • 4710
                      • Russia
                      #450
                      Originally posted by Salvocchio
                      Some doubts:
                      But everything is clearly drawn in the diagram, remove the ceramic capacitors, put tantalum capacitors in their place (the capacitance is written in the diagram), the resistors are placed in the gap (the tracks are cut).
                      • toptib
                        • Apr 2012
                        • 18
                        • ita
                        #451
                        If the panel is 100% working, then you can install another motherboard (and hope that the motherboard will also work).
                        Hi Lotas,Do you know if I mount a UE55MU6400UXTZ on my tv UE40MU6400UXTZ can I change the panel on the service menu?
                        • lotas
                          • Jan 2016
                          • 4710
                          • Russia
                          #452
                          There are also positional resistors on the board for different sizes of diagonals, it’s better to look for ones with the same diagonal as yours. You can read the dump T-con (25Q80), there may also be a problem with it and post it here, I’ll take a look and write down the panel number.
                          • Diah
                            • Feb 2013
                            • 6424
                            this diagram old version of the programmer... the black one only need the vcc to move it to 3,3V.. that's all . i have one just have this modifying of VCC,, no need connect it to pin 9 other wise it will be short circuit on the black one
                            • toptib
                              • Apr 2012
                              • 18
                              • ita
                              #454
                              I am attaching the contents of the video eprom.
                              Unfortunately I can't find cards for 40'' at the moment.
                              Thank you for your time
                              • lotas
                                • Jan 2016
                                • 4710
                                • Russia
                                #455
                                If you completely switch the programmer to 3.3v power supply, then 9 pin is connected to 3.3v (there is absolutely no need to install a jumper for 5v power supply!)
                                https://vil2.livejournal.com/780.html
                                • lotas
                                  • Jan 2016
                                  • 4710
                                  • Russia
                                  #456
                                  What panel do you have, number CY-xxxxx? And the full model number of your TV.
                                  • Diah
                                    • Feb 2013
                                    • 6424
                                    NO lotas.... pin 9 on black one.. no need to connect at all.. even remove C or add R no need too.... just VCC bridge it to 3.3v to protect spi eeprom if they cant handle 5 V... again only the black ONE samre to post photo # #441 with out any add of r or cut rail
                                    • lotas
                                      • Jan 2016
                                      • 4710
                                      • Russia
                                      #458
                                      Open the datasheet on CH341A and look at 9 pin if you switch to 3v power supply. In the circuit for modification, there is no need to remove the capacitors, but replace them with tantalum of higher capacity.
                                      https://4pda.to/forum/index.php?show...st&p=125980884
                                      • lotas
                                        • Jan 2016
                                        • 4710
                                        • Russia
                                        #459
                                        • toptib
                                          • Apr 2012
                                          • 18
                                          • ita
                                          #460
                                          panel CY-KK040HGNV2H
                                          tv UE40MU6400UXTZ
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
