Samsung ue49mu6120
This topic is closed.
  • Dan_TV
    • 7
    • italy
    #381
    Hi Lotas,
    I appreciate a lot, It works!!! I'm really glad about that.
    I have another question for you:
    I have also a replacement mainboard with the following codes:
    BN41-02568B
    BN94-12644G
    UE49MU6199UXZG
    Is it compatible with my actual mainboard (UE49MU6120KXZT with BN41-02568A and BN94-12570P)
    Is it possible configure this creating replacement board for the previous UE49MU6120KXZT with BN41-02568A and BN94-12570P?
    Thx
    • lotas
      • Jan 2016
      • 4708
      • Russia
      #382
      May differ in panel firmware.
      • Dan_TV
        • 7
        • italy
        #383
        But is it possible with a bin file fix that mainboard to work with that panel?
        Can you help or explain me?
        Thx
        • lotas
          • Jan 2016
          • 4708
          • Russia
          #384
          Well, did you connect this board to the TV, was there an image?
          T-con firmware (panel settings...) are in 25Q80.
          • Dan_TV
            • 7
            • italy
            #385
            25Q40 had blank dump so I tried to write the last bin you give me.
            Now the screen is blank and red led blink.
            Can I fix the 25Q80 firmware with the CH341 programmer?
            Thx
            • lotas
              • Jan 2016
              • 4708
              • Russia
              #386
              Yes, you can, just save all the dumps, they can still be useful if the problem is not in them, and it was also the original dump that you posted, did you write the status register (0x88, 0x42) after recording my working dump?
              • Dan_TV
                • 7
                • italy
                #387
                Yes, I do that on my TV UE49MU6120KXZT:
                Mainboard BN41-02568A BN94-12570P fixed 25Q40 with your dump "25q40_orig_fix.bin" setting status register => now works
                Now I have a second mainboard that I'd like to configure to have a replacement for the future if my original BN41-02568A BN94-12570P will have other problems. It is:
                Mainboard BN41-02568B BN94-12644G (25Q40 had empty dump) I fixed 25Q40 with your dump "25q40_orig_fix.bin" setting status register => no image and red led blinking. Now I suppose I have to fix the 25Q80. How I do that?
                Thx
                • lotas
                  • Jan 2016
                  • 4708
                  • Russia
                  #388
                  From your native one, read dump 25Q80 and write it to another (preserving its native one), they also have positional resistors on their motherboards for different panels, diagonals.
                  You need to compare so that everything matches.
                  • Dan_TV
                    • 7
                    • italy
                    #389
                    Do you have a picture to see what area positional resistors are located in mainboard?
                    thanks
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Hi Lotas, I have a UN49MU7000 that has no standby and i believe the eeprom is the problem. Can you please check it for me and correct if something is wrong.
                      Thanks in adavance
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        #391
                        Thanks in adavance
                        Hi. Try.
                        • Storyteller12
                          • Jun 2020
                          • 625
                          Hi. Try.
                          I tried it, but for the life of me I cannot get the registers set to 0x88 0x42. It's always 0xFC 0x42 even after changing the protection and writing. It shows successful but 0xFC
                          I have rt809f programmer and should be able to set registers. Even after I erase everything and verify the registers still 0xFC 0x42
                          Am I missing something or doing something wrong
                          • lotas
                            • Jan 2016
                            • 4708
                            • Russia
                            #393
                            First, we define the flash, remove the protection (uncheck the boxes and press write), erase, write a dump, check, install the protection (check the boxes and press write).
                            • Storyteller12
                              • Jun 2020
                              • 625
                              I did exactly as described and have the same 0xFC for register 1
                              update: I quit being lazy and removed the ic from the board and it worked right away. Lesson learned.
                              thanks again for the help
                              • lotas
                                • Jan 2016
                                • 4708
                                • Russia
                                #395
                                You always need to remove the chip from the board, especially when recording it; I don’t trust this clothespin (problems can always arise).
                                • eliodoro
                                  • Apr 2020
                                  • Italia
                                  #396
                                  Samsung UE55MU6100XZT
                                  This led's tv have a stand-by ligth on and after power on ...the stand.-by go off but the panel ligth flash and the tv not power on....no audio no immage
                                  Lotas, can you chek the spi flash dump attached is corrupt and eventually fix it?
                                  Tank's in advance....Francesco
                                  • lotas
                                    • Jan 2016
                                    • 4708
                                    • Russia
                                    #397
                                    Your dump is working.
                                    • Jeffaas
                                      • Jan 2021
                                      • 11
                                      • Nederland
                                      #398
                                      Hi Lotas, could you please check my dump? it is from a UE49MU6400 and doesnt show the standby led. all voltages are ok.
                                      thanks in advance!
                                      • lotas
                                        • Jan 2016
                                        • 4708
                                        • Russia
                                        #399
                                        Try.
                                        • Jeffaas
                                          • Jan 2021
                                          • 11
                                          • Nederland
                                          #400
                                          Thanks! The tv works again.
                                          respect! And many thanks!!!
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
