Samsung ue49mu6120
This topic is closed.
  • Alberto
    • Sep 2015
    • 17
    • Caceres
    #181
    Re: Samsung ue49mu6120
    Originally posted by lotas
    There may be a problem when removing or installing spi flash 25q40, the components moved around this memory (resistors ...), if you used a soldering station with hot air, the flash itself is not working properly, there may be a problem in the T-Con firmware (25Q80), the problem is in panels...
    we have tried with a main board from another television and everything works correctly, so we believe it is a firmware problem of this board.
    the memory has been removed with a jbc RMSE-2QF station and all the components are perfect around it.
    I don't know if you can guide me further.
    thank you
    • lotas
      • Jan 2016
      • 4708
      • Russia
      #182
      There are four firmware chips on this board, these are two spi flash - 25Q40, 25Q80, one eeprom 24C512 and one eMMC.
      • Alberto
        • Sep 2015
        • 17
        • Caceres
        #183
        do you have the firmware to test the 25q80 and the 24c512?
        It is the last test that I have left to do, I am desperate.
        Before reprogramming the 25q40 chip it did not do anything completely dead and when reprogramming it there is standby and it blinks but no image or backlight.
        Thank you very much for your time and dedication, I am very grateful
        • lotas
          • Jan 2016
          • 4708
          • Russia
          #184
          But they are unlikely to help, the T-Con settings and everything related to your panel (diagonal, manufacturer, specific settings ...) are stored in the 25Q80, try replacing the 25Q40 with another one.
          • lotas
            • Jan 2016
            • 4708
            • Russia
            #185
            Usually such behavior, as I already wrote, does not match the software version in SPI Flash (25Q40) and in eMMC.
            • Alberto
              • Sep 2015
              • 17
              • Caceres
              #186
              i tried with a new w25q40 chip and same problem.
              convinced that the problem is the firmware because there is no response signal on 25q40 with oscilloscope
              • lotas
                • Jan 2016
                • 4708
                • Russia
                #187
                Try another option.
                • lotas
                  • Jan 2016
                  • 4708
                  • Russia
                  #188
                  I understand everything perfectly, the fact is that when you turn on the TV, the processor checks the checksum with the spi flash and with the emmc area, and if it does not match, then exactly the same problem as yours will come out.
                  • Alberto
                    • Sep 2015
                    • 17
                    • Caceres
                    #189
                    Try another option.
                    tested and with this file it gives standby slow flashes
                    • lotas
                      • Jan 2016
                      • 4708
                      • Russia
                      #190
                      Let's try different software versions.
                      • Shwed84
                        • Feb 2023
                        • Russia
                        #191
                        I have the same problem with my
                        SAMSUNG UE40MU6470UXRU .Can you help me ?
                        Thank you
                        MB: BN41-02568B
                        LCD: CY-KK040HGNV3V
                        the number on the sticker: BN94-11958K
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          #192
                          Thank you
                          MB: BN41-02568B
                          LCD: CY-KK040HGNV3V
                          Try.
                          • Alberto
                            • Sep 2015
                            • 17
                            • Caceres
                            #193
                            Problem solved. I have put in a new main board and everything works fine.
                            Thanks for all the help and interest shown Lotas.
                            Thank you
                            • Jovica123
                              • Oct 2017
                              • 80
                              • N/A
                              #194
                              Hello lotas please fix my dump
                              Samsung ue55mu6270uxzg
                              Thank you in advance !
                              • lotas
                                • Jan 2016
                                • 4708
                                • Russia
                                #195
                                Try.
                                • Jovica123
                                  • Oct 2017
                                  • 80
                                  • N/A
                                  #196
                                  Thank you,it is working !
                                  • bmt_hr
                                    • Sep 2012
                                    • 8
                                    • Croatia
                                    #197
                                    Maybe You can check this attached file good or not.
                                    BN41-02258A, UE55KU6070
                                    • joaoubina
                                      • Jan 2017
                                      • 5
                                      • PORTUGAL
                                      #198
                                      HI dear friend Lotas . can you help me?!!!
                                      iI have a samsung UE49MU6205K and no power on , can be the same??
                                      • joaoubina
                                        • Jan 2017
                                        • 5
                                        • PORTUGAL
                                        #199
                                        i forgote the file ,
                                        • lotas
                                          • Jan 2016
                                          • 4708
                                          • Russia
                                          #200
                                          Your firmware (Dump) is working!
                                          Also try this dump, if it doesn't start with it, then you have another problem.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
