plasma imidge cleaner on menu
  • cadiman
    • Mar 2010
    • 397
    Is this for screen imidge burn repair? (imidge cleaner on menu) I use this full white for setting v and waveforms per the set up manual. Thanks,
    Cadiman
  • Wizard
    • Mar 2008
    • 2296
    Re: plasma imidge cleaner on menu
    don't use cleaner. Nothing you can do to correct burn in. This is nature of the phorphors-based design.
    Cheers, Wizard
      LCD LED TV Service Menu Codes
      ALL LCD LED TV SERVICE MENU CODES
      Service Menu Code with Board Name
      China Universal Board / Jumper Board Service Menu Code
      Changhong Ruba Service Menu Code
      Ecostar LED TV Service Menu Code
      Orient LED TV Service Menu Code
      Haier LED TV Service Menu Code
      TCL LED TV Service Menu Code
      Samsung LED TV Service Menu Code
      LG LED TV Service Menu Code
      Videocon LED TV Service Menu Code
      Supra LED TV Service Menu Code
      Toshiba LED TV Service Menu Code
      Symphony LED TV Service Menu Code
      Veste/ LED TV Service Menu Code...
      10-31-2024, 03:58 AM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • howardc64
      Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
      by howardc64
      Eventually discovered a burn mark near lower corner of LCD. Here is a summary
      • Backlight on, no image
      • Disconnect right buffer board (view from front), left side display comes on
      • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
      • Buffer board is pretty simple
      Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
      07-11-2025, 04:04 PM
    • Robby-Gr
      TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
      by Robby-Gr
      I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
      However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
      The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
      Additional issues:...
      09-27-2025, 12:02 AM
    • Retro140
      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
      by Retro140
      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
      06-18-2023, 06:13 PM
