LG OLED 55EG9100 TCON troubles
  • Diah
    replied
    Re: LG OLED 55EG9100 TCON troubles
    Originally posted by Big_Whity
    Hello there,
    I have the same issue. After some vertical Lines on my LG OLED C7D, i swapped the T-Con Board.
    With the new Board, the lines are gone, but i see ghost logos like "Dolby Vision" "HDR" etc. all over the Screen.
    I wanted to downgrade my OLED and update it again, but i cant find an older version of the firmware... Does anybody know where i can find it? My firmware is 6.00.25.
    all LG TV series from 2014 to 2021 ( old & new web OS Firmware ) can downloaded from LG server with help this site server,
  • Big_Whity
    replied
    Hello there,
  • Diah
    replied
    with wifi never work... only LAN
    GATEWAY --- yours PC IP
    DNS Server ---- yours PC IP
    yours PC should with LAN too
  • Andrei_UK
    replied
    Originally posted by Diah
    yours pc firewall blocking communication , or you write the ip gate way on the tv wrong
    No luck same , I try wifi, wired connection same , I even try 3 firmwares and the original one too
  • Diah
    replied
  • Andrei_UK
    replied
    show me screen on \LgDTVUpDater\htdocs show all files, or use this blank file instate the one you have
    well i think its not my job to teach computer science over here.... or !!!
    Thank you for taking from your time, but stii the same nothing written even on blank files
  • Diah
    replied
    Originally posted by Andrei_UK
    I did probably 5 times and still not come up the model in the in dumb.txt nothing change on the files
  • Andrei_UK
    replied
    in_dumb.txt is just quide to know the name of new file generated under C:\LgDTVUpDater\htdocs for exampel HE_DTV_XXXXX_XXXXX so look after which file generated new ... you will know this when your PC explorer setting can show the exit type of the file and date time stamp. also you can delete the perviouse in_dump.txt content it will generate new one
  • Diah
    replied
    Nothing change in the ( in_dumb.txt ) the model_NM of the TV
    Everything it’s done except in_dumb.txt
  • Andrei_UK
    replied
    here how to do in German language.. you can translate it to English via the browser. it is very easy.. attached also the Apache server.
    Everything it's done except in_dumb.txt
  • Andrei_UK
    replied
    Hi, thank you, I will try now .. I let you know later how it's going on , thank you again
  • Diah
    replied
    Like I said it's a different story and I also said maybe I will talk about the B8 upgrade later ( for you maybe sounds not good idea ) and I have done it 9 month ago , and still working as normal.
  • Andrei_UK
    replied
    sorry man.. i cant share my mind with subject you are running unclear to us.. you have 2 OLED and you exchange parts between them.. TV OLED like pc when take the hard disk from PC to pc.. when you exchange parts this parts should register the new hardware against the old registered... some time this make JAM
  • Andrei_UK
    replied
    Sorry for misunderstanding, I have extra motherboard C9 which it's already upgraded on the B8 TV ( it's a different story)
    It's dosed have nothing to do with my other C9 TV which I was talking about and try to find solutions to match the new T-CON to the panel or to find a solution to fix the old and original T-CON from the TV
    Thank you
  • Diah
    replied
  • Andrei_UK
    replied
    you are just jumping between solutiones, mean while i never heared on this heating error..
    rollingback firmware more easy.. because downgrade you need old firmware version which LG remove them from download. unless you write at any forum of this model if some one upload it for you.
    however i will try to write to you later how to rollingback the firmware.. mean while when you install the old T-CON did you screw it complete with the metal shield and chassis ?
    Hi
    I find on a china lg website any firmware version for C9 , I try with the USB to install but dose not see any file the TV .. what options are to downgrade firmware if I have the early files?
    Thank you
  • Andrei_UK
    replied
    Maybe later I will talk about the upgrade experiment I have done ( maybe someone will be interested to know or to do it )
    I have upgrade my B8 with C9 motherboard I confirmed that all works good on the B8
    C9 motherboard + wifi card with the switcher ON/OFF
    See pic the update works too
  • Andrei_UK
    replied
  • Andrei_UK
    replied
    why you play with LG service RC ??? you dont have its RC????
    and why you dont programm the Tv channel ??? or at least feed it with external HDMI signal ???? or play movie mpeg with USB drive ?????
    Oh, sorry I recorded just to see all the menu settings from the service menu coz like you know the tv turn OFF between 30 sec - 1 min and then to compare with the new T-CON
    I do have 3 RC + service RC
    I will add new video with Burn Test 5% grey with the old T-CON and a video with my OLED55B8 and the C9 with the old T-con
    https://youtu.be/4Um_XMKYzj0 burn test
    https://youtube.com/shorts/8wU7d7teWk8?feature=share B8 vs C9 old T-CON damage
  • Diah
    replied
    I have video with the tv ON with the old T-CON the picture it’s quality
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 07:12 AM
    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:40 AM
    Gigabyte AERO 16 OLED BSF-73US994SH Notebook Specification for Upgrade or Repair
    This specification for the Gigabyte AERO 16 OLED BSF-73US994SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73US994SH boardview and 16 OLED BSF-73US994SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 06:38 AM
