Sharp LC-80LE632U T-con? white stripe?
  • griffweegus
    • Oct 2021
    Hi guys- does this look like a bad t-con board to you? It weird that it is only 1/4 the screen and not 1/2. I don't want to order the board without you guys looking at it since I'm a novice.
  • Storyteller12
    • Jun 2020
    • 625
    Re: Sharp LC-80LE632U T-con? white stripe?
    Don’t think it’s a tcon issue. Looks like one of the panels Cof tabs is damaged. Pretty much non repairable without expensive specialized equipment.
    • griffweegus
      • Oct 2021
      Originally posted by Storyteller12
      Don't think it's a tcon issue. Looks like one of the panels Cof tabs is damaged. Pretty much non repairable without expensive specialized equipment.
      My thought too. Thanks for looking!
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • moltensolderlabs
        Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
        by moltensolderlabs
        Hi everyone. [Sorry for the long, detailed post in advance].
        I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
        10-09-2020, 12:01 PM
      • zoontz
        SHARP LC-70UD27U black and white lines
        by zoontz
        Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
        What I have tried so far.
        I have tested all HDMI inputs with the same results.
        I have checked for firmware updates.
        I have reset to factory settings.
        I have removed...
        07-09-2024, 05:50 PM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
