Un50mu6070 Mainboard issue
  • lotas
    • Jan 2016
    • 4668
    • Russia
    #41
    Re: Un50mu6070 Mainboard issue
    1. Cut the tracks in three places
    2. We solder the 4.7k resistors into place
    3. We restore the VCC circuit (8 pin power) using a jumper
    4. As a result, it should look something like this
    • lotas
      • Jan 2016
      • 4668
      • Russia
      #42
      And also the cost of powering the matching lines of the chip of the programmer itself from 5v to 3.3v.
      • Storyteller12
        • Jun 2020
        • 624
        Ok, I don't have any 4.7k resistors. I will have to order them.
        Is there another CH341A programmer that works without modifying it?
        If not what is the next programmer to get that doesn't require mods?
        • lotas
          • Jan 2016
          • 4668
          • Russia
          #44
          RT809F
          https://aliexpress.ru/item/100500345...archweb201603_
          • ducky29
            • Dec 2015
            • 370
            • Europe
            #45
            Is this modification required only for the register problem?
            Will the programmer work fine for other chips as well? I mostly do eeproms 24CXX and 25QXX at home,also for reading and programming radios that require ISP connections.
            • lotas
              • Jan 2016
              • 4668
              • Russia
              #46
              Yes, everything else will work as well.
              • Storyteller12
                • Jun 2020
                • 624
                UPDATE: FIXED!!!
                Received new programmer. First attempt did not work with your firmware Lotas. Not sure if I did something wrong or not. It was my first attempt using this programmer with the supplied software.
                However I did get it to work after loading the original eeprom dump from the 55" donor board i used.
                I have attached the dump from that eeprom to help anyone else that might need it.
                Thanks again for all the help Lotas. Appreciate your time and expertise.
                Last question, I have a Sony tv with a bad emmc. Will this RT809F programmer work for this? If not any recommendations.
                • lotas
                  • Jan 2016
                  • 4668
                  • Russia
                  #48
                  RT809F will not cope with EMMc, RT809H will do, but it does not cope well with EMMc firmware, especially by Sony, a good programmer for NAND and EMMc is UFPI.
                  http://mslw.com/shop/
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4367
                    • Italy - Milan
                    #49
                    what does matters to the programmer which is the content of the memory?
                    • lotas
                      • Jan 2016
                      • 4668
                      • Russia
                      #50
                      A good programmer should not just read and write, but be able to work with bad blocks (nand), work with partitions (EMMc), display the percentage of EMMc health, prepare a dump, be able to write it down correctly, observing the table, and much more.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4367
                        • Italy - Milan
                        #51
                        coming back to the ch341 problem, how can it write correctly the status register2 if previously it has protected it by programming srp0 (status register protect 0, if i remember it refers to the other register) to on? it is not that QE is not changeable because it is in conflict with other settings?
                        • Storyteller12
                          • Jun 2020
                          • 624
                          Hey Lotas,
                          How do you fix the bin files we provide you?
                          I have a Samsung Soundbar I’m pretty sure the eeprom is bad. I dumped the chip already but not sure how to tell if anything is bad or missing.
                          Thanks for all the help. If you have PayPal I would be happy to donate for your knowledge and time.
                          • lotas
                            • Jan 2016
                            • 4668
                            • Russia
                            #53
                            Originally posted by Storyteller12
                            Hey Lotas,
                            I am fixing with a HEX editor and knowledge, what happened to the Samsung Soundbar?
                            • Storyteller12
                              • Jun 2020
                              • 624
                              Long story short.
                              It would power on. But only stay on “BT” Bluetooth. I could not switch input or change volume. I tried unplugging the remote/ ir board and the buttons on the top of the unit separately with no success.
                              I could not get it to update through usb either.
                              So after all that I’m assuming it’s the eeprom or another ic related issue possibly.
                              I was starting with the eeprom since I have the programmer now
                              • lotas
                                • Jan 2016
                                • 4668
                                • Russia
                                #55
                                What model, what is the motherboard number?
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  Don’t have the motherboard in front of me.
                                  But the model is HW-Q90R.
                                  I have repaired it few different models of theses with bad power supplies. They all seem to have the same internals. ( power supply, motherboard, speaker output boards.
                                  It seems the software is the main difference.
                                  • Storyteller12
                                    • Jun 2020
                                    • 624
                                    Hey Lotas,
                                    Here are pics of the motherboard just to follow up
                                    • lotas
                                      • Jan 2016
                                      • 4668
                                      • Russia
                                      #58
                                      Hello here the firmware is in 3 chips EMMC, EEPROM, SPI FLASH.
                                      • Storyteller12
                                        • Jun 2020
                                        • 624
                                        Thanks for the info. Not sure where to go from this point. I’m pretty sure it’s software related issue though.
                                        • ducky29
                                          • Dec 2015
                                          • 370
                                          • Europe
                                          #60
                                          UPDATE: FIXED!!!
                                          What programmer did you use? Did you make the modifications that iotas mentioned or it worked straight away?
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • notallbad
                                            TCL 55RP620K power board issue
                                            by notallbad
                                            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                            0% p_dim at 1.65v and a_dim at 1v
                                            50% p_dim at 3.3v and a_dim at 1.65v
                                            100% p_dim at 3.3v and a_dim at 2.88v
                                            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                            Leds are 2 rows of 15 6v leds.
                                            On inspection of the power board found diode MBR3200 shorted so replaced with...
                                            07-12-2025, 05:45 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • eclectric
                                            Sony Bravia KDL-70W850B T-CON board / software update issue
                                            by eclectric
                                            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                            05-23-2022, 01:25 AM
                                          • corrize
                                            Nikon D5 – dead, power board issue ?
                                            by corrize
                                            Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                            When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                            I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                            Now, I try to understand how it works.
                                            There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                            04-03-2023, 09:13 AM
