LG 43UF6400 - displays static on all inputs, sound works, menus look and run perfect
  • Noobwithamultimeter
    • Apr 2021
    • 94
    I wonder if it's the mainboard or t-con board. I also wondered why nobody else has posted about this model yet.
    • Apr 2021
    • 94
    Re: LG 43UF6400 - displays static on all inputs, sound works, menus look and run perf
    Here is what the inside looks like.
      • Apr 2021
      • 94
      There is an audible high pitched "pinging" sound coming from the mainboard when plugged in, but not powered on. Maybe one of the chips with the heatsinks over it.
        • Apr 2021
        • 94
        Had luck finding a solution with a comment on a youtube video!
        SOLVED the issue this week. My 55" LG TV was doing the exact same thing. But it's now working perfectly, and it didn't cost me anything to fix it. I had tried the "reflow oven trick", which is putting the motherboard in the oven at 380 degrees for 10 minutes. That did nothing, but I didn't give up, and tried 3 more times.
        First time: 380 degrees for 10 mins = no result
        Second time: 400 degrees for 10 mins = no result
        Third time: 400 degrees for 15 minutes = mostly clear picture with a slight static
        Fourth time: 405 degrees for 18 minutes = issue fixed!
        Motherboard was placed on cardboard from an Amazon box, and placed in the center of the oven. Make sure to let the motherboard cool for about 45 minutes - 1 hour after being in the oven before reinstalling.
        Hopefully this will help someone else who is having a similar issue.
        *Why does this work? The soldering on these motherboards can crack / disconnect over time. Even 1 poor solder connection on the motherboard can cause a static screen. Putting the motherboard in the oven will re-melt the solder, and letting it cool properly will allow the connections to "reset". You will get a nasty smell from your oven while doing this, but it's normal. Just have a window / door open with a fan on. *
        I did the same, but skipped step 1 and 2 and tried step 3 because it sounded the most promising, but he was absolutely right there were flickers, now I'm trying 405 degrees for 18 minutes...
          • Apr 2021
          • 94
          I only disagree with putting cardboard in the oven, I used a flat pan with four tiny balls of aluminum foil under each corner to keep it all level.
          • neilc6
            • Nov 2015
            • 1550
            Baking boards with BGA issues is only a temporary fix. Problem will come back in weeks or months.
            • handsworth
              • Oct 2015
              • 174
              There are professionals who repair this problem at a reasonable prices. Ive had it done a couple times. However since they have been baked, they may refuse to repair it. The BGA is a common problem with the LG UF series.
              • Comp_Pro
                Macbook Air 820-00165 Static Chime Sound
                by Comp_Pro
                Hello all,
                I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                11-02-2023, 03:23 PM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • diggitt
                Radio, no stations, quiet static sound
                by diggitt
                I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
                04-14-2025, 05:06 AM
              • Christos Tsiligiannis
                Marian Trace Alpha sound card repair help
                by Christos Tsiligiannis
                Hello to the forum.
                My name is Christos, I am new to the forum here and i am posting from Greece.
                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                11-18-2024, 05:26 AM
                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:30 PM
