Samsung UN32EH5300 BL on no picture
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    im trying to save tv from trash
    tv powers on with backlight ok.. sound ok
    no picture
    i test voltages coming from PS all seem ok..i have 3.3v 5v and 12v
    i test fuse on tcon and is ok
    i have 0 volts at the tcon board fuse though
    so i imagine this is a main board issue?
    thanks
  • 3DIL
    3D!L
    • Jun 2021
    • 42
    • BRASIL
    Re: Samsung UN32EH5300 BL on no picture
    In the tcon you have two LEDs, one that indicates that it is receiving 12v, the other led usually more to the right indicates that it is on, with a bridge between the pins of the two ends where the two flex cables that go to the panel are connected. you can make it work i send you images.
    THAT WAY YOU CAN SINGLE A CABLE FROM ONE SIDE OF THE LCD PANEL AND ALTERNATE
    • 3DIL
      3D!L
      • Jun 2021
      • 42
      • BRASIL
      The bridge goes between the first pin of the right connector and the last pin of the left connector
      • shelby5041
        • Feb 2009
        • 1505
        My tcon no have 12v so no on
        • 3DIL
          3D!L
          • Jun 2021
          • 42
          • BRASIL
          then the problem comes from the main one, you have to check fet near the LVDS connector I will try a diagram
          • 3DIL
            3D!L
            • Jun 2021
            • 42
            • BRASIL
            here I leave you the service manuals I hope it helps you solve, good look
              09-07-2024, 05:50 AM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • jesterace
              Samsung UE46ES8000 Blown fuse but no other signs of short
              by jesterace
              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
              09-11-2024, 03:14 PM
            • iglitare
              by iglitare
              09-04-2025, 07:13 AM
            • Dobsuk
              Samsung UE50TU8000K no picture or lanes on it
              by Dobsuk
              Hi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
              And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
              The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes...
              04-25-2023, 07:34 AM
