Hisense 507D
  • wirphotos
    • Sep 2019
    • 18
    Hisense 507D
    Picked this tv up from a family member. Tv was working fine and then they started having issues. Tv would turn on, show an image and shortly after it would shit down.
    I've done some research and did a system reset. The screen comes on and the video is fine in setup. I've had it already where I could watch tv on it for a 30 hour. Other times it will turn on show the splash screen and shut down.
    I'm at a lost as it works great after a full reset, but then after a while it goes back to it's old ways.
    Help!
  • Sibiemofokeng
    • Mar 2020
    • 5
    • South africa
    Re: Hisense 507D
    Maybe the main board is the same as 55A7,after replacing the new main board of this tv it played well for one day, the following day when I switched on the screen shows no picture but backlight was there on,I cleaned the cables from t-con board to screen thereafter picture came back.
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      Yesterday, 11:45 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • Scruit
      Does the Oak OTI067 have a splash screen / initialization message at bootup?
      by Scruit
      tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
      More detail:
      Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
      My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it....
      04-17-2022, 06:03 AM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
