Sony KD75XE9005 Bottom half double image
  • Formaster
    • Jul 2021
    • 68
    • Switzerland
    Hi guys,
    I'm tyred from these sympthom, if anyone helps me really big thx.
    When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?
  • Formaster
    • Jul 2021
    • 68
    • Switzerland
    Re: Sony KD75XE9005 Bottom half double image
    I masked a small section from the T-CON ribbon cable. Now the picture shows without any failure, but don't know what caused the problem.
    • lotas
      • Jan 2016
      • 4753
      • Russia
      You have a problem in the panel on the SKV lines
      • Formaster
        • Jul 2021
        • 68
        • Switzerland
        Thx, sadly did'nt saw the picture below from this black line, before wrote the last comment. Is there any possibility to repair this?
        • lotas
          • Jan 2016
          • 4753
          • Russia
          No, this black line cannot be fixed.
          • lotas
            • Jan 2016
            • 4753
            • Russia
            Either way or panel replacement.
            • Formaster
              • Jul 2021
              • 68
              • Switzerland
              Made some new pictures, while the line isn't black, it is green and going not trough the whole screen. Is exactly panel issue?
              • lotas
                • Jan 2016
                • 4753
                • Russia
                After SKV amputation on the non-working side of the panel, a thin line remains on the screen.
                • Formaster
                  • Jul 2021
                  • 68
                  • Switzerland
                  Thats mean can't be repaired? I'm really sad, this TV has a brilliant picture
                  • budwich
                    • Jul 2015
                    • 3097
                    some sets (sharp) that have a similar problem can be "saved". The "save" involves removing the tabs on the side of the panel of the "non-working side" IF the set has side driver boards / tabs along each side. You have to remove the front plastic bezel to see how the set is built... to see the tabs and driver boards. IF you are lucky, this operation may remove the black line as it is related to the tab driver on the side. CAUTION: the operation CAN NOT be reversed... that is once the tabs are removed they can not be put back so this needs to be your last resort effort. Post more pictures of the sides of the panel so that the forum can see what the design is like and provide more guidance.
                    Also note: some sets (newer ones) don't have side tabs / drivers external from the panel (like those pictured on the bottom edge) and they are built into the panel itself. You are unlikely to be able to save these sets with this type of failure.
                    • Formaster
                      • Jul 2021
                      • 68
                      • Switzerland
                      Thank you, i just sold is so. This is a huge work on this big boy and the build quality make it more difficult. But it is good to know
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        Well, it's right that they sold it to him, the panel will not last long, because the panel is very large and the working (duplicating) SKV will need to power its own and non-working half of the panel, for it it will be a big load.
                        • budwich
                          • Jul 2015
                          • 3097
                          Currently, a 70 inch sharp, that had its side tabs removed, has been running daily for over 5 years so it might last longer than in its "non-failed" operational mode. :-)
                          • lotas
                            • Jan 2016
                            • 4753
                            • Russia
                            Well, here, how lucky you are 50/50.
                            • budwich
                              • Jul 2015
                              • 3097
                              guess that's better than the zero for not trying.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4464
                                • Italy - Milan
                                Budwich you don't know what you are saying, Sharp of many years ago are another thing, today's screens are made with no side tabs..
                                Some months ago i was developing an experimental technique using mini drill and a diamond 1mm tip to make a hole in the beginning of the faulty line/gate driver.. it needs a special technique to not ruin the panel.. i succesfully find it but i have made experiments not on a tv with this fault but on a cracked screen.. i have no tv like this, very difficult to find on market.. these months i'm not repairing any more things..
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  yes... you didn't read what I said. I indicated if the set did not have any side tabs then the save is likely not possible with the "removal method" as it is not there to remove. You probably should have bought the OP tv to fix it with your "method".
                                  • howardc64
                                    TCL 49S405 double image
                                    by howardc64
                                    LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                    This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                    06-23-2025, 03:20 PM
                                  • viewfindr
                                    Samsung UN46D6500VF - no display, odd lines and double image on half of display
                                    by viewfindr
                                    Hi there, I'm seeing some tips/advice on how to pinpoint what might be going on with my TV. This is a continued discussion from this thread, as users suggested I should start a new topic to discuss my problem. In summary:
                                    Before I took the set apart, I started to see a double image come on after the set is powered on for a few minutes. (attachment #1).
                                    I came across this YouTube video, which seemed to describe a very similar phenomenon from what I was seeing. (In summary, the video suggests unplugging one cable, and using a small clear piece of tape to cover various...
                                    05-02-2020, 03:27 PM
                                  • Cornito
                                    Samsung UE55RU8000 reboot and then double image after heating up
                                    by Cornito
                                    Hello team,
                                    I'm back with another tv and another problem.
                                    I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                                    First, reboot issue, I use tape Method to find out the right side that cases the issue.
                                    Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                                    Then double image reduce in height and move to the top.
                                    The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                                    When I...
                                    03-31-2024, 01:37 PM
                                  • NSkyLab
                                    Sony XBR-65X900F black and white image on one side (fading saturation)
                                    by NSkyLab
                                    I though I've seen all possible kinds of failures but this one is new...
                                    Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
                                    I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
                                    Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
                                    10-05-2025, 07:37 PM
                                  • bubbajoey
                                    Sony Bravia KDL-65W850C red tinge and double image
                                    by bubbajoey
                                    Long time lurker first time post.
                                    I was recently gifted a KDL-65W850C that had a faulty backlight LED, replaced the strip and it now has a functioning backlight.
                                    The issues now are that skin tones are red and also I'm getting double images
                                    and "ghosting"? on right hand side. I have attached pics.
                                    Also the "tab" on top right of panel is hot to the touch, when I do touch it does affect the picture slightly. The other tabs are cool to the touch. Pic also attached...finger in (pic because camera wouldn't focus)...
                                    03-25-2021, 11:56 PM
