Protron PLTV-32c
  • mrosenberg42
    • Aug 2008
    • 27
    Protron PLTV-32c
    Hello all,
    I have a Protron PLTV-32c that has no standby power or any other voltages for that matter. I read the posts about the PLTV-3250 and it sounds like the same issue but a different power supply. I checked all transistors, diodes, zeners and found no bulging caps. Everything checks out ok. Granted everything was checked in circuit and no components have been pulled off the board and checked, which will be my next move. I think I'll start with replacing all electrolytics and then pulling off zeners and checking them outside the circuit. Does anyone by chance have a schematic of this power supply: FSP232-4M01. These surface mount diode and transistor markings are cryptic. Color bands are hard to read etc. It would be much easier to be able to reference a schematic. Anybody else have the same issue with this LCD or have any suggestions? Would be much appreciated. Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Protron PLTV-32c
    Originally posted by mrosenberg42
    Hello all,
    There are a few (very few!!) schematics of TV power supplies floating around. From the few I've seen, the standby supply is usually a very simple supply. I'd suggest treating that as a simple power supply and starting with the basics. Make sure the main filter cap has the proper voltage (1.4X line voltage), the SMPS chip is getting appropriate voltages, and the output diode and load aren't shorted.
    Pay particular attention to small electrolytic caps around the SMPS IC. Because of the 'bootstrap' design of these supplies an open cap can prevent the standby supply from even starting.
    PlainBill
    • mrosenberg42
      • Aug 2008
      • 27
      Thanks for the reply. I did check ESR of all electrolytics and all measured ok. The filter Cap is at 160v which is 1.4x as you suggested. I am definitely missing something. I still don't trust any of the caps. Like I said earlier I'll start with recapping the whole supply check the smps chip voltages and then work through the other components one by one. Thanks again.
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
