Philips PUS6501 - no picture
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Philips PUS6501 - no picture
    Since things seem to be intermittent. I would heat sections of power board and note any difference. Also check solder joints with a magnifying glass.
    • nomoresonys
      • 12112
      • U.S.
      +1, heat up the caps with a hairdryer, see if it turns on.
      • nomoresonys
        • 12112
        • U.S.
        Kind of suspect a capacitor, if it isn't a backlight connection or led.
        • betmen
          • May 2019
          • 90
          • Croatia
          I removed 4 electrolitic capacitors C8120-C8123, all four are good.
          I measured two smd capacitors in circuit and they are not in short circuit and R8148 is OK.
          Earlier I seen that optocoupler U9306 in stanby circuit have 0V on pins 3-4 on transistor, I wonder is that relevant?
          Also there is no intermittent LED light any more, LEDS are not working at all, but when I test it with backlight tester on connector they are working.
          Any new ideas?
          • matthewmcconaughey
            I need help with my friend Sony GDM-FW900 24” CRT
            by matthewmcconaughey
            Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
            I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
            1. It started with a bright and greenish picture upon starting a cold monitor.
            2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
            05-16-2023, 03:15 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • madyoyo
            Philips 37pfl560: Yellow picture
            by madyoyo
            HI.
            I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
            Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
            05-30-2025, 10:16 AM
          • maneatingmonkey
            Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
            by maneatingmonkey
            I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
            There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
            03-27-2024, 07:17 AM
