Repair or Replace
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Repair or Replace
    From today in the UK all electrical good must have spares available for 10 years in order that landfill use is reduced.
    Since this also applies to TV's it will be interesting to see how it pans out.
  • mmartell
    • Oct 2013
    • 3189
    Re: Repair or Replace
    Probably means the manufacturer will keep ONE spare lightbox on hand at twice the price of the tv.
    • SLK001
      • May 2014
      • 264
      It would be nice if the manufacturers would again release a service manual for their electronics. I get so tired of tackling a PCB blind.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I remember when you walked past the Radio & TV shop the pavement would be strewn with schematic diagrams mixed in with the empty boxes waiting to be collected by the refuse collectors.
        • budwich
          • Jul 2015
          • 3097
          they can have all the spares you need / want BUT unless there is some "control" on pricing, it is likely that the end result will still be alot of "recycling".
          • diif
            • Feb 2014
            • 6978
            • England
            It's not all electrical goods. Ovens, hobs, microwaves and tumble dryers are exempt as is personal tech such as phones and laptops.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              BBC News does not rule out white goods in the 10 year plan.
              https://www.bbc.co.uk/news/business-57665593
              • diif
                • Feb 2014
                • 6978
                • England
                They need to employ better journalists that understand what they are writing about. This article details what is covered and what is not. https://www.bigissue.com/latest/envi...d-your-family/
                • petehall347
                  • Jan 2015
                  • 4430
                  • United Kingdom
                  they will still make and sell more new and "better ones "
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • RetroComputingGrotto
                    Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                    by RetroComputingGrotto
                    I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                    As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                    What is your advice/opinion on whether or not on old(er)...
                    04-03-2024, 08:30 AM
                  • chth96
                    Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                    by chth96
                    I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                    Since then, This AC/DC adaptor have been out of order.
                    But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                    After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                    And Is there any possibility that it will suddenly explode as well as to be out...
                    12-03-2023, 04:40 AM
                  • disorder
                    HP 2311 display, 3.3v regulator fried, need help to replace
                    by disorder
                    hello,
                    i have a hp display 2311 to repair, totaly dead
                    on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                    i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                    thank you
                    07-27-2025, 04:34 AM
                  • psyduck
                    Conformal coating on Samsung U32D970 monitor PSU, do I need to replace after repair?
                    by psyduck
                    I have a Samsung U32D970 monitor from 2015 I pulled out of the bad hardware pile that turned on and then turned itself back off after a few minutes of use and refused to turn back on. The PSU has part number BN44-00786A, and I found a couple posts about one that had blown with damage to the MOSFETs and PWM controller - but nothing about intermittent failures. I started a new thread and said that I would refresh the solder joints on the board to see if it was just a bad connection and possibly replace the PWM and PFC ICs. I then asked what my next course of action would be after those steps. I...
                    11-27-2023, 06:56 PM
