Strange issue with United LTV 19X83WDVBT LCD TV
  • sushy74
    • Jun 2020
    • 12
    • Italy
    Good evening, I have a problem with this lcd tv (UNITED branded with BEKO electronics), I would need to fix it to try some old video game consoles as it has digital / analog tuner.
    I found it after years and once I turned it on I realized that it took a while to go from standby to operational, but above all I notice that it is blocked in some way, let me explain ... no physical button on the TV works, using the remote control (which is a compatible one) only some keys work, such as the one for power, volume, numbers and little else, I cannot change source and above all it does not access the menu in any way.
    I opened it to check the integrity of the components and I noticed a fairly swollen electrolytic on the psu, I replaced it and the problem of delayed start has disappeared ... the other problems remain and in fact make tv unusable.
    I tried various procedures to enter the service menu for both United and Beko models but there is no way to succeed, I also tried to use an Android mobile phone with this function as a remote control and it doesn't change anything, only the buttons mentioned above work .. . is there any reset procedure? it's probably stuck on some Hotel / Kids type mode.
    Thanks to anyone who can suggest something
  • sushy74
    • Jun 2020
    • 12
    • Italy
    Re: Strange issue with United LTV 19X83WDVBT LCD TV
    Anyone can suggest what to try? I'm really going crazy with this tv...😟
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Menu 9301 to enter the service mode.
      • sushy74
        • Jun 2020
        • 12
        • Italy
        This doesn't work...menu function seems not responding either from remote or tv button
        • sushy74
          • Jun 2020
          • 12
          • Italy
          Is there a way to do an hardware reset directly on the pcb?
          any suggestion?
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
          • ahmarzo
            Acer laptop battery draining issue
            by ahmarzo
            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
            08-02-2025, 06:39 AM
