Cheap LED backlight replacements?
  • spleenharvester
    • Mar 2010
    • 903
    I have an LG 42LN540V that is blowing LEDs. Blew the first one at Christmas, didn't have a spare so just pulled it off and jumped with solder. This week it blew another one (different strip). I'm weighing up whether to replace all the strips as I suspect it's going to keep doing it.
    I see complete replacement strip sets for £12 from Ebay. This seems way too cheap to be true to me. Does anyone have any experience with these? Am I better off buying a used OEM part?
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Cheap LED backlight replacements?
    When LEDs start dying it's time to replace all of the strips with new.
    A whole set from Ali is even cheaper than from ebay and will arrive in about 10 days.
    I've just bought a set for an identical LG.
    • spleenharvester
      • Mar 2010
      • 903
      Thanks, thought this was the case. I'll get some strips ordered for the next time it inevitably goes kaput.
      • diif
        • Feb 2014
        • 6978
        • England
        I used to replace individual LEDs but when a whole set is delivered for less than £15, there is no point.
          i used to replace individual leds but when a whole set is delivered for less than £15, there is no point.
          +1
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • Kingfreddie
            LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
            by Kingfreddie
            Ok.. this is the story:
            Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
            This is kinda how it looked, just that mine were at the bottom of the screen:
            09-11-2021, 01:57 AM
