Samsung PS43f4500AWXXU Plasma Faulty Y Board
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Samsung PS43f4500AWXXU Plasma Faulty Y Board
    I would do the usual checks, look for shorts on IGBTs, open resistors, and test the buffer ICs, use the positive probe on FGND, and negative one on each output pins on the connectors for the panel.
    • reessi
      • Jan 2016
      • 334
      • uk
      I replaced the Y SUS board again from ebay and the TV is working.
      For anyone else to summarise:
      Although the components are replacable due to the age they are only available from chinese sellers on ebay/aliexpress they appear to all be rebadged parts. The 30J127 part definitly had totally different diode readings to an original! It is impossoble to troubleshoot/fix something when you do not even know if the new parts are working!
      Buying a whole board or anything else of Aliepress is very risky, almost no re-course if faulty. Mine had faulty connectors resulting in black lines. It took me several weeks of online chats with aliexpress to get a refund and to start with they wanted me to post to china at my expense. Just use ebay! It is very hard to access the ALiexpress chat!!! I also have to wait up to 60 days for the refund..
      Cheers.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Cooperr
        Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
        by Cooperr
        I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
        The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
        10-21-2025, 01:11 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
