Does Samsung LN55C630 TV have a service menu?
  • dave8647
    • Mar 2021
    • 6
    I have found various videos and web sites that provide codes for the Samsung TV "secret" service menu. None of these work for my LN55C630. So either I just haven't found the right code, or maybe this model does not have such a thing.
    Does anyone know?
    Similar models include LN40C630, LN55B550, LN40B550 etc.
  • nomoresonys
    • 12187
    • U.S.
    Re: Does Samsung LN55C630 TV have a service menu?
    The first two here are usually what gets me into the older sammys:
    Method 1
    Put TV on standby and then these buttons in series on the remote: 'info, menu, mute, power' the TV will then turn itself on and display the service menu.
    Method 2
    Turn the power off. On the remote, press {Mute} followed by {1},{8}, {2}, {Power} in sequence. If successful the service menu will now display.
    Method 3
    With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
    Method 4
    With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
    Method 5
    With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
    Method 6
    With the TV in standby. On the remote, press {MUTE} followed by {1} {1} {9} {ENTER} in sequence.
    • nomoresonys
      • 12187
      • U.S.
      Sometimes it may take many tries of same sequence to get in if you take too long between remote button presses it won't work.
      • dave8647
        • Mar 2021
        • 6
        Thanks. Your method 2 worked, on the second try.
        I was interested in seeing if there is some way that the manual controls could have been turned off, such as some hotel mode setting, but I don't see any such option and the hotel mode is off.
        I do see the red standby light when the set is off, and I can press the area just to the right to turn the set on, I just don't see the illuminated symbols. The channel and other button areas also work, but are harder to guess the location.
        So I guess there must be some hardware issue. But as long as the remote works, it's not worth it to me to try fixing that.
          09-07-2024, 05:50 AM
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
