Panasonic Plasma tc-p55vt50 6 blink error code
  • orbit417
    • Apr 2021
    • 10
    Hi All,
    Thank you in advance for your advice.
    I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
    I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
    I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power supply which I did and blinks didn't change indicating the power supply. I swapped out the power supply and found no change. At that point I decided I should take a look a closer look before changing any other parts.
    Attached you'll see photo's of the SC board where I found shorted chips (sorry not sure what they're called). I figured I could just order a new SC Board and be done with it but unfortunately I couldn't find one anywhere on the internet.
    I really like my TV and would like to hold onto it if I could get it working.
    Jimmy
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic Plasma tc-p55vt50 6 blink error code
    Why are both of your pictures backwards (reverse image)?
    • orbit417
      • Apr 2021
      • 10
      Sorry about that. I took the photo's with the mobile using the front camera. I never knew it reversed the photo.
      I've uploaded new photo's as I'm sure that's gotta be annoying to see everything in reverse
      SC Chip:
      SC Board:
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        Those are RJP30Y2A IGBTs that shorted, there might be more shorts, if you want to repair this board you'll have to desolder all of them and test off-circuit, gate drivers for those might also be shorted, need a hot air station and a soldering iron for that.
        Or you can just test the SS, SC1 and SC2 buffer boards for shorts, if they are ok, buy a replacement SC and the TV will be back to working, keep the screws tight and only power up with all of them on SC and SS boards.
        • orbit417
          • Apr 2021
          • 10
          Thank you Biruslapio
          I took your advice and looked up a video on how to check the SC1 & SC2 buffer boards and no shorts found. I'll see what I can located for the SS board and let you know.
          I'm more than happy to purchase a new/used SC board but I'm unable to locate the exact one. They're several NTPA2228 boards on the internet but none of them are 100% match for my model TV. I found this model https://www.tvpartstoday.com/TXNSC1R...txnsc1rfuu.htm which is close but seems to be missing some of those 'RJP30Y2A IGBTs'. Any idea if it's compatible?
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            The board should be a TNPA5528AE, the AF variant is used on the 50 inch P50ST50, which consumes less power so if it's lacking IGBTs and/or MOSFETs compared to yours it would be a bad idea to try it on a 55 inch panel.
            Comparing AE and AF, AF seems to have less heatsinks.
            • orbit417
              • Apr 2021
              • 10
              Thanks again Biruslapio for your help.
              I did some quick googling on AE board and it seems to be missing the IGBTs and/or MOSFETs and heatsinks. Do you still think it's safe to use?
              AE Board: https://www.tvpartstoday.com/TXNSC1R...txnsc1reuu.htm
              When googling I found the difference in labeling of these boards is that NTPA2228 has a number '2' under the label vs the NTPA2228AE which has a number '1' under the label.
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                Something is weird with these AE models, there's also 2 different revisions:
                TXNSC1REUU with a missing diode, D6301 and a RJP IGBT. Those are for P55ST50.
                TXNSC1RAUU which looks like yours, for P55VT50, I don't know how much it would matter, need to test it on the TV and chech how much those transistors and diodes heat, best to buy the RAUU if it's similarly priced and available.
                https://www.shopjimmy.com/panasonic-...w-525142560103
                https://www.shopjimmy.com/panasonic-...-1205715118537
                • orbit417
                  • Apr 2021
                  • 10
                  I never noticed the slight difference in model #'s TXNSC1RAUU vs. TXNSC1REUU and yes I agree the TXNSC1RAUU would be the board to get. Unfortunately I don't believe they make it anymore and I unable to located a used one anywhere.
                  Would you recommend purchasing the TXNSC1REUU board which is available online and adding those missing MOSFETs & Heatsinks or testing ever component on my current board and replacing the broken ones?
                  • Biruslapio
                    • Nov 2013
                    • 552
                    • Brasil
                    You would have to solder the missing transistors, their gate resistors, diodes and heatsinks, check the entire board for SMD resistor differences between the boards, or compare each model's service manual schematic side by side.
                    P55ST30 may have different voltages generated by the SC that are often configured via SMD resistors in series, like VSCN, Vad, VSET, if they differ from your VT to a ST series panel, your image quality may drop as a result of they being different and requiring the expected SC sustain voltages, VT has a higher maximus power consumption than ST, so soldering those missing components would be needed.
                    • orbit417
                      • Apr 2021
                      • 10
                      I have my work cut out for me... Everything you mentioned in your last post I'm completely unfamiliar with and will take a significant amount of time for me to learn. I have a lot to consider...
                      Thank you again Biruslapio for your help and insight on the matter.
                      In case I do decide to trouble shoot each component is there a site or thread you'd recommend for learning about testing them?
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        I remember this thread:
                        https://www.badcaps.net/forum/showth...t=84516&page=4
                        Where the user bought fake 30F124 IGBTs for their LG Y-SUS, so if you end up buying 45F122 or RJP30Y2A I suggested comparing them to originals, physically and electrically if possible, as there are a lot of fake parts being sold.
                        To do a proper maintenance I would dessolder all IGBTs and MOSFETs and test them off circuit for leakage or shorts, their gate resistors (the green ones next to them), their gate drivers and their switching ICs, called buffers in the schematic, those SMD diodes, there's a lot to test, SC board repair is time costly if you're a beginner in electronics.
                        Service manual for this TV is bad and the schematics for SC board are low resolution, unreadable.
                        < link to service manual
                        It's viable too to wait for a proper SC board be announced for sale.
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          I dont think the board from the 50 inch will work. I tried it on a 55gt30. The tv turned on but tbe display was totally consumed with pink malcharge, unwatchable. At least it confirmed my SC was bad.
                          • orbit417
                            • Apr 2021
                            • 10
                            Thanks again Biruslapio for the links. After zooming in all the way on that schematic I don't think it's possible for me to fix. I think I'm going to wait for a used one to show up on ebay.
                            • orbit417
                              • Apr 2021
                              • 10
                              Thank you TVTimmy
                              You've saved me the headache of ordering an SC board that appeared to be 'close enough' to mine and then finding out it that it wouldn't work :-)
                              • orbit417
                                • Apr 2021
                                • 10
                                *Update - my TV is working :-)
                                After searching high and low for a new or used SC board I finally came across an electronics' repair shop on Ebay. I was hesitant at first as I had to pay for the service in advance and then pay to ship the board to his shop and wait anxiously for him to return it repaired. The whole process took about 2-3 weeks and in the end I now have a working TV :-)
                                So for everyone coming to this thread for assistance with a Panasonic VT50 with 6 blinks of death the SC board was the culprit and the mosfets and resistors had indeed failed (see first pic thread).
                                Thanks again for everyone's help.
                                • LongLiveMyPlasma
                                  • May 2020
                                  • 11
                                  Could you please post the name of the eBay repair shop? I'm having the exact same problem and I'd love to get this thing repaired.
                                  • cloo
                                    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                    by cloo
                                    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                    After doing a factory reset this problem was gone and the picture was back to...
                                    01-06-2025, 06:02 AM
                                  • rmacintosh
                                    Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                    by rmacintosh
                                    I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                    The symptoms of the tv ar as follows:
                                    • Plug AC in to back of TV
                                    • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                    • The 3 blink code is given by the power LED
                                    • If the TV is unplugged and then
                                    03-14-2020, 12:24 AM
                                  • jm1234
                                    Panasonic plasma TX-P42ST50 - 6 blinks
                                    by jm1234
                                    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                    I checked that board for any obvious faults...
                                    05-22-2024, 06:59 AM
                                  • stecos
                                    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                    by stecos
                                    Hi everyone!
                                    For my passion for technology I'm now collecting several...
                                    11-28-2022, 11:39 AM
                                  • Andre Gilbert
                                    by Andre Gilbert
                                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                    11-20-2024, 08:52 PM
