Soniq E40S12A-AU Stuck In Standby
  • Eggbert43
    • Jul 2014
    • 47
    Re: Soniq E40S12A-AU Stuck In Standby
    I see, thank you for clarifying....
    So, with the set plugged in & switched on, I put the black lead/plug to ground & the red to each pin of the connectors?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      That's correct with meter set to dc.
      • Eggbert43
        • Jul 2014
        • 47
        Ok, so my cheap LCR Tester (TC1) arrived & I have been playing with that instead of measuring those voltages we spoke of sorry; I may still need to take those voltage readings at the CN connectors, but first:
        After getting some suspect readings with my TC1 from some of the components on the Power Board, I unscrewed the board to look at the back of it, & there is something in particular that looks wrong to me. I have circled the area in question on the attached images & would really appreciate your thoughts.....
        The two +12V Pins On CN201 seem to have a big chunky bit of solder attached to them; plus, are the two +12V pins supposed to soldered together like that?
        Please see attached; either way, I will be replacing some of the capacitors on this board next....!
        • Eggbert43
          • Jul 2014
          • 47
          Actually, it probably is normal; two of the three +24V pins on CN203 seem to be connected/soldered together also..., mmmm.....
          I'll come back with Voltage readings from these connectors in the next day or so......
          • Diah
            • Feb 2013
            • 6435
            all pins normal 12v and 24v. you wrote, it power on displaying splash screen then screen go black then back to red standby.
            do the following, disconnect the LED backlight socket from the backlight driver ( white color socket ) then power on the tv... just remark if it stay on or it back to stand by... if it back to standby just power it again with remote control..
            • Eggbert43
              • Jul 2014
              • 47
              Thank you so much for your input Diah...
              I just need to clarify which one the Backlight Driver is; is it the board down the bottom of Photo 01, or the board at the top left of Photo 02?
              There is a white chord going from a white plug/socket on the bottom board to a white plug/socket on the top left board; I suspect you might be telling me to unplug it from the top left board???
              Please see the attached photos
              • Eggbert43
                • Jul 2014
                • 47
                Actually, when I say the bottom of Photo 01, I mean the top of Photo 01; rotation wasn't preserved.....
                • Eggbert43
                  • Jul 2014
                  • 47
                  Now I'm thinking you might be talking about the White Socket to the far left of the top left board in Photo 02. The chord travels up from this one to the top of the TV somewhere?
                  I have attached a close-up image of the connector on the top left board; the connector is circled in red..... I am not even sure if this board is the Backlight Driver; please enlighten me
                  • Diah
                    • Feb 2013
                    • 6435
                    yes this socket, its LED backlight which it goes to the led behind the screen.
                    • Eggbert43
                      • Jul 2014
                      • 47
                      Ok brilliant, will test & report back shortly....
                      • Eggbert43
                        • Jul 2014
                        • 47
                        Powering up with that connector disconnected results in the exact same behaviour/symptoms, except the splash screen doesn't flash on for a split second.
                        An interesting development which I should've noticed earlier, is that there is a faint image on the screen when I hold a torch up to it & I can navigate the menus etc
                        I should've noticed this earlier, because I can navigate the menus with a torch regardless of whether or not the LED Backlight connector is plugged in or not.
                        Most of all, I now know that the TV isn't turning off & returning to standby.
                        The redlight disappears once the TV has booted, & only reappears as a solid red if I press the power button.
                        I apologise for originally miscommunicating the symptoms; for some reason I assumed the TV was switching off.
                        I hope this tells you more than it did me, because I'm not even sure if any of this is good or bad news; in terms of difficulty to fix, or at least diagnose further?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          If the backlights flash and then go off and with or without them connected you can navigate the menu on the screen then you probably have a led(s) or led connector fault.
                          Also with the led connector in place if the backlights flash you should see the voltage peak at switch-on if you measure the led connector pin voltage to chassis.
                          Repeat the measuement for each pin with the set being switched on out of standdy.
                          • Eggbert43
                            • Jul 2014
                            • 47
                            Thanks mate, an LED fault sounds bad, costly, difficult to remedy....
                            Is the LED Connector the one I disconnected for diagnosis/testing purposes just now; the one I circled in my most recent attachment?
                            • Diah
                              • Feb 2013
                              • 6435
                              this what i first expected there are error at the fault description. this why i asked you if red led come on just power it on again with remote.
                              now do this,
                              put back the socket of the led back. and turn on the set.. when the screen turn black just unplug the socket on the inverter boards ( 24V supply , the big one ) and plug it in again fast. the led backlight will come on again.. this tell us you have led backlight issue need to repair.
                              • Eggbert43
                                • Jul 2014
                                • 47
                                Thanks Diah, I really appreciate your help!
                                I just did as suggested, but quickly removing & plugging in the big connector on the Inverter Board did not bring the backlight back on
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  you need to read he voltage as following on the led socket we talked on before.
                                  put yours digital meter on DC 200V
                                  you have on the socket
                                  pin 1 VCC and then led-1 /led-2 ( put the meter red probe on the VCC and the black on led-1 then turn on the tv record the voltage you get when tv displaying splash screen and with out.. do the same to the led-2 )
                                  same way you do for the another group VCC pin 5 and led -1/led-2
                                  all test should be when you turn on the set, post here here your reading with label
                                  VCC pin 1 ----led -1 pin 2=
                                  VCC pin 1 ----led -2 pin 3=
                                  VCC pin 5 ----led -3 pin 6=
                                  VCC pin 5 ----led -4 pin 7=
                                  • Eggbert43
                                    • Jul 2014
                                    • 47
                                    VCC (Pin 1) >> LED 1 (Pin 2) = 37V Powering On & 4.0V Post Boot
                                    VCC (Pin 1) >> LED 2 (Pin 3) = 65V Powering On & 4.6V Post Boot
                                    VCC (Pin 5) >> LED 3 (Pin 6) = 10V Powering On & 4.0V Post Boot
                                    VCC (Pin 5) >> LED 4 (Pin 7) = 63V Powering On & 4.0V Post Boot
                                    My Digital Multimeter is very basic, & the Voltage readings when powering up were flashed for a split second, before calming down to the post boot readings....
                                    LED 3 had to be attempted many times due to not giving any reading at all when powering up; so she seems very suspect.
                                    I also know that LED 2 gave a 72V reading on one occasion.....
                                    Thoughts?
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      backlight issue. need to take screen apart to start repair
                                      • Diah
                                        • Feb 2013
                                        • 6435
                                        Thoughts?
                                        you can try slide out the wire of this pin out from the sockets, be sure to cover it with type so didn't make contact with chassis then turn on the tv hope the reset will turn on so you can use the tv for awhile.
                                        • Eggbert43
                                          • Jul 2014
                                          • 47
                                          Very interesting idea, will definitely try it....
                                          LED 1 is a concern also though.... Can it really work with only 3 LEDs? 2 LEDs even?
                                          • Loagz
                                            Soniq S55V14B-AU Stuck in Standby
                                            by Loagz
                                            Hi, I'm hoping someone can point me in the right direction....
                                            I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
                                            After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they...
                                            11-15-2021, 02:13 AM
                                          • nubie
                                            Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
                                            by nubie
                                            Please help me ID the blown chip and point me where the short might be.
                                            I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
                                            The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
                                            Anything I should check first for a short?
                                            Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think...
                                            01-05-2023, 06:06 PM
                                          • samsonn
                                            Soniq S55V16A-AU stuck in standby
                                            by samsonn
                                            I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
                                            I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting...
                                            06-28-2020, 02:33 AM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
